Samsung Galaxy A5 (2016) Battery Replacement
  1. Samsung Galaxy A5 (2016) Battery Replacement, Back Cover: step 1, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement, Back Cover: step 1, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement, Back Cover: step 1, image 3 of 3
    • Start by switching off your phone.
    • Take an iOpener to heat up and soften the glue behind the back cover.
    • With a suction handle lift the back cover to insert an opening pick.
  2. Samsung Galaxy A5 (2016) Battery Replacement: step 2, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 2, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 2, image 3 of 3
    • Slide the pick up to the middle to separate the back cover from the frame.
    • Insert a second opening pick and move around the right corner along the bottom and around the left corner.
  3. Samsung Galaxy A5 (2016) Battery Replacement: step 3, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 3, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 3, image 3 of 3
    • Take another opening pick and continue towards the top corner.
    • Here you want to use one more pick for the last part at the top.
  4. Samsung Galaxy A5 (2016) Battery Replacement: step 4, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 4, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Insert a plastic card at the bottom and slide it underneath the back cover.
  5. Samsung Galaxy A5 (2016) Battery Replacement: step 5, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 5, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 5, image 3 of 3
    • Heat up the back cover once again so you can slide the plastic card towards the top.
    • Always take a peek underneath the back cover to not damage any parts like the NFC antenna.
    • Move the plastic card until you reach the camera bump. Now slowly lift up the back cover and finally remove it.
    • Be sure to remove any residue from the glue and apply new adhesive when reassembling.
  6. Samsung Galaxy A5 (2016) Battery Replacement, Battery: step 6, image 1 of 2 Samsung Galaxy A5 (2016) Battery Replacement, Battery: step 6, image 2 of 2
    • Remove the SIM card tray.
    • Remove the 17 Phillips #00 (3.4 mm) screws on the midframe.
  7. Samsung Galaxy A5 (2016) Battery Replacement: step 7, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 7, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 7, image 3 of 3
    • Push the exposed part of the battery away from the midframe to separate the components.
    • You may need the IMEI sticker on your old battery to identify your phone in the future, be sure to transfer it to the replacement battery.
  8. Samsung Galaxy A5 (2016) Battery Replacement: step 8, image 1 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 8, image 2 of 3 Samsung Galaxy A5 (2016) Battery Replacement: step 8, image 3 of 3
    • There is a plastic spacer between the battery and the midframe that requires a metal prying tool to remove before the battery can be replaced. Be extremely careful not to puncture the battery.
    • Use the Jimmy to carefully pry the plastic battery spacer out from the daughterboard end of the battery cavity.
    • Remove the plastic spacer from the phone.
  9. Samsung Galaxy A5 (2016) Battery Replacement: step 9, image 1 of 1
    • Again carefully pry up the battery and insert the tip of an opening pick on the left side.
    • Now you can use a second opening pick and slide it in on the right side. Also don't insert too far to avoid damaging the LCD screen underneath.
  10. Samsung Galaxy A5 (2016) Battery Replacement: step 10, image 1 of 2 Samsung Galaxy A5 (2016) Battery Replacement: step 10, image 2 of 2
    • Slide with the opening picks towards the top to free the battery of the adhesive.
    • Now you can remove the battery.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
54 other people completed this guide.
Tobias Isakeit
117,504 Reputation
188 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,528 Guides authored
19 Comments
Guten Tag,
Ich habe meinem Battery ausgetauscht, nach dem Austausch das Volume Taste und sim slat 2 funktioniert nicht mehr.
wie kann ich die reparieren?
vielen dank
peyman - Reply
Prüfe, ob die Kontakte der Lautstärkeknöpfe und das Flachbandkabel noch in Ordnung sind (nicht verschmutzt oder verbogen). Das mit dem Sim Slot klingt schon etwas seltsam. Das Modell in dieser Anleitung hat nur einen Sim Slot und einen micro-SD Slot.
Tobias Isakeit -
Hi in step 7 you can see a black thin plastic over the battery. Is it the NFC antenna?
carolinaaires - Reply
Yes, this is the NFC antenna.
Tobias Isakeit -
Just saved 2k INR by following this guide !!! Thanks Man
priyadarshi - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 147
All Time: 91,570
