Saeco Minuto outer case
  1. Saeco Minuto outer case, Open a Saeco Minuto: step 1, image 1 of 1
    • Disconnect the power plug!
    • Remove the water tank.
    • Remove all the coffee beans.
    • Remove the brewing assembly.
    • Remove the drip tray and the coffee grounds drawer.
  2. Saeco Minuto outer case: step 2, image 1 of 3 Saeco Minuto outer case: step 2, image 2 of 3 Saeco Minuto outer case: step 2, image 3 of 3
    • Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
    • When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
  3. Saeco Minuto outer case: step 3, image 1 of 2 Saeco Minuto outer case: step 3, image 2 of 2
    • Remove the Torx T10 screw at the top edge of the coffee dispensing spout.
  4. Saeco Minuto outer case: step 4, image 1 of 2 Saeco Minuto outer case: step 4, image 2 of 2
    • Lift off the black cover over the coffee dispensing spout. The sliding nozzles will come off at the same time.
  5. Saeco Minuto outer case: step 5, image 1 of 1
    • Remove both Torx T10 screws on the left and right at the bottom edge of the coffee dispensing spout.
    • Pull off the hot water dispensing spout.
  6. Saeco Minuto outer case: step 6, image 1 of 2 Saeco Minuto outer case: step 6, image 2 of 2
    • Remove the Torx T20 screw on the finger guard of the grinder. Remove the finger guard.
    • If the screws are covered with coffee remains, you should first clean them with a needle and a vacuum cleaner.
    • Remove three Torx T10 screws in the bean container.
  7. Saeco Minuto outer case: step 7, image 1 of 1
    • Remove the three Torx T10 screws under the water tank.
  8. Saeco Minuto outer case: step 8, image 1 of 3 Saeco Minuto outer case: step 8, image 2 of 3 Saeco Minuto outer case: step 8, image 3 of 3
    • Grab the upper cover on the sides and lift it up.
    • The cover is still connected with a cable and a tube.
    • Take off the silicone tube.
  9. Saeco Minuto outer case: step 9, image 1 of 1
    • Remove the water level sensor cable from its brackets.
    • Carefully remove the plug from the water level sensor.
    • The cover is now free and can be removed.
  10. Saeco Minuto outer case, Saeco Minuto outer case: step 10, image 1 of 3 Saeco Minuto outer case, Saeco Minuto outer case: step 10, image 2 of 3 Saeco Minuto outer case, Saeco Minuto outer case: step 10, image 3 of 3
    • Open the service Dior.
    • Remove five Torx T10 screws.
  11. Saeco Minuto outer case: step 11, image 1 of 1
    • Remove one T10 Torx screw securing the top of the grinder.
  12. Saeco Minuto outer case: step 12, image 1 of 2 Saeco Minuto outer case: step 12, image 2 of 2
    • If you haven't already done so: Unscrew the center Torx T10 screw at the bottom of the coffee spout distributor.
    • Unscrew the Torx T10 screw in the middle left front.
    • Lift the service door up and remove it.
  13. Saeco Minuto outer case: step 13, image 1 of 2 Saeco Minuto outer case: step 13, image 2 of 2
    • Unscrew the Torx T10 screw securing the coffee spout distributor inside.
  14. Saeco Minuto outer case: step 14, image 1 of 1
    • Lift the coffee spout distributor up and remove it.
    • The coffee spout distributor tends to be dirty. Open it and clean it thorougly.
  15. Saeco Minuto outer case: step 15, image 1 of 1
    • You should now be able to lift the inner frame out of the outer one. On some models, it is still attached with other screws.
    • Lift the inner frame up and remove it from the outer case. It may get stuck a bit, help with a plastic lever tool.
  16. Saeco Minuto outer case: step 16, image 1 of 3 Saeco Minuto outer case: step 16, image 2 of 3 Saeco Minuto outer case: step 16, image 3 of 3
    • This is what the inner frame looks like from three sides. All components are easily accessible, especially the pump, the flowmeter and the heater.
  17. Saeco Minuto outer case: step 17, image 1 of 1
    • And this is what the completely gutted outer case looks like. It can now be cleaned well.
Repeat the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
de en
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
201,668 Reputation
246 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
25 Members
1,097 Guides authored
One Comment
For the Saeco Pico Barista, it is pretty much the same…
This manual was a big help to fix the unit (t° sensor on boiler had to be replaced).
Thx !
Kurt Van Collie - Reply
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 148
All Time: 3,839
