Introduction
In order to access the internal components such as electronics, heater, pump and flow meter, the inner frame must be removed from the outer housing. This guide shows how to do it.
Remove the water tank.
Remove all the coffee beans.
Remove the brewing assembly.
Remove the drip tray and the coffee grounds drawer.
Pry up with a plastic opening tool at the bottom edge of the chrome-plated cover to lift up the coffee dispensing spout. This cover is often very tight, so you have to pry hard and hope that the part does not break.
When the lower edge of the spout is released, you can pry on the side edge until the chrome cover comes off completely.
Lift the coffee spout distributor up and remove it.
The coffee spout distributor tends to be dirty. Open it and clean it thorougly.
Repeat the steps in reverse order to reassemble your device.
4 other people completed this guide.
Special thanks to these translators:
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
One Comment
For the Saeco Pico Barista, it is pretty much the same…
This manual was a big help to fix the unit (t° sensor on boiler had to be replaced).
Thx !
