Introduction
The device has to be opened for many repairs, which is shown here. The side panel with the service cover may also be removed, but this is not necessary for most repairs.
Remove all accessory parts like the water reservoir, the brewing assembly as well as the drip try.
Remove all coffee beans from the bean container
Remove the two T10 Torx screws from the bottom of the rear cover.
Remove the five T10 Torx screws as marked
the back frame consist of 3 pieces. Lift the top part out first, then each one of the side pieces
Lift the bean compartment lid and loosen the Torx T10 screw.
Open the water compartment lid and loosen the Torx T10 screw.
The lid is locked into place several times. Carefully loosen the catches and lift off the lid.
Open the front access door.
Lift the top cover by about 2 cm until you can just reach the screw in the top right.
Remove the T10 Torx screw
Work through the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
100%
VauWeh is helping us fix the world! Want to contribute?
Start translating ›
3 Comments
Hallo. Ich habe das Problem das ich die Antriebs Zahnräder der Brühgruppe der Saeco Exprelia HD8855 falsch eingesetzt habe. Kann mor da einer helfen?
Zur Orientierung hilft vielleicht das hier: Saeco Royal Cogwheel replacement, Schritt 23: Setze das graue Zahnrad beim Einbau so ein, dass die Nullmarkierung auf die Achse des weißen Zahnrads zeigt.
VauWeh -
