STERWINS 360ep 3w-1 Blade replacement
    • Turn the mower off and turn it over to access the blade.
    • Position the correct size pipe wrench or socket wrench on the blade nut.
    • Lock the blade in the opposite direction of unscrewing with a piece of wood and hold it firmly.
    • Unscrew the blade nut while firmly holding the blade shim.
    • Remove the blade fixing bolt and its washer. Place them close, they will be reused to fix the new blade.
    • Remove the worn blade from its holder.
    • Place the new blade on the support, matching the shape of the support pins with the cutouts on the blade.
    • Insert the fixing bolt with its washer and start to screw it by hand into the blade holder.
    • Using the shim and the pipe or socket wrench used for disassembly, tighten the blade fixing bolt.
    • Check the blade tightness using a torque wrench. The tightening must be 40 Nm.
Well done, you just replaced your blade
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Clément Delporte
382 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 8
Past 7 Days: 73
Past 30 Days: 207
All Time: 4,441
