Shop the Holiday Gift Guide
SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix
Views: 5.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
52
Past 30 Days:
213
All Time:
5,403
Comments: 6
1 comment on steps, 5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This will guide you with disassembly of the right speaker and volume knob; and fix for Audio cutting out when adjusting the volume knob on the headphones. The fix bypasses the volume knob so you will no longer be able to adjust the volume on the headphones. If you want you can replace the Thumbwheel Potentiometer.
Tools
    1. SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Remove Right Ear Pad & Screw Covers: step 1, image 1 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Remove Right Ear Pad & Screw Covers: step 1, image 2 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Remove Right Ear Pad & Screw Covers: step 1, image 3 of 3
      • Remove right ear pad by pulling outward. See attached PDF on how to remove.
      • Remove 5 screw covers with a toothpick.
      • Remove 5 screws with #1 Philips screw driver.
      Ask FixBot
    2. SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Detach Volume Circuit Board: step 2, image 1 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Detach Volume Circuit Board: step 2, image 2 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Detach Volume Circuit Board: step 2, image 3 of 3
      • Remove right speaker. But be careful with speaker cable as it is not very long.
      • Set volume knob all the way to 0% muted. Should fell a click by turning all the way counter-clockwise.
      • Remove 3 #00 Philips screws on circuit board.
      • Volume circuit board should come off. Some of the glue might hold it in, un-stick the glue with a very small flat head screw driver by prying it off the plastic housing.
      Ask FixBot
    3. SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Removing Volume Knob: step 3, image 1 of 2 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Removing Volume Knob: step 3, image 2 of 2
      • Remove Philips screw in the center and this will allow you to remove the knob.
      • Careful with not to touch the very sticky grease that makes the knob turning motion smooth.
      Ask FixBot
    4. SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Fix Audio Cutting Out Problem: step 4, image 1 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Fix Audio Cutting Out Problem: step 4, image 2 of 3 SENNHEISER GSP 500 Gaming Headset / Headphones Disassembly and Audio Fix, Fix Audio Cutting Out Problem: step 4, image 3 of 3
      • To bypass the Thumb-wheel POT volume control: Solider a jumper wire (red wire in picture) from pin #2 to last pin #5 and pin #3 to pin #4 (solider bridge). Also leave the volume at the MAX position. This will prevent shorting the POT to Vcc to GND.
      • To bypass the mute switches: Solider R11 with a jumper wire and R12 with a jumper wire, as shown. This will bypass the mute switches.
      Ask FixBot
4 other people completed this guide.
Author
with
hectorhmoreno
226 Reputation
1 Guide authored
5 Guide Comments
I had the right speaker break loose inside the housing. Thankfully the wires didn't break. I was able to glue it back in place and it's working fine again. Thanks for the teardown guide. I wasn't sure how to get into it to fix it.
Dillon Sly - Reply Share
Awesome! Glad you got them works again.
hectorhmoreno - Reply Share
It worked perfectly, thank you.
Simón C. - Reply Share
Such an easy fix for a really annoying problem. Thank you for creating this guide. Saved me from buying a new headset :)
Rubick - Reply Share
Works for GSP 600 as well. Thank you, problem solved!
Pavlik - Reply Share
Past 24 Hours: 5
Past 7 Days: 52
Past 30 Days: 213
All Time: 5,403
