Introduction
This guide demonstrates how to replace the magnetic storage tray located above the battery. This guide requires opening the drill, but does not require removing any of the internal electronic components.
Parts
No parts specified.
  1. The battery can shock you.  Only touch plastic, non-conductive components. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards. Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
    • The battery can shock you. Only touch plastic, non-conductive components.
    • Detach the battery unit from the drill body by pressing the battery release buttons on both sides of the unit and pulling outwards.
  2. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior. Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
    • Use a Torx T10 screw driver to unscrew all ten 13.5 mm screws from the drill casing to gain access to the interior.
  3. Gently lift the casing from the drill body. Take the casing completely off the drill body to gain access to the interior of the drill.
    • Gently lift the casing from the drill body.
    • Take the casing completely off the drill body to gain access to the interior of the drill.
    • The Ryobi P202 casing has Part #: 200690001
  4. Gently lift the magnetic tray from the bottom of the drill body. The magnet is Part #: 303001015
    • Gently lift the magnetic tray from the bottom of the drill body.
    • The magnet is Part #: 303001015
Joseph Eckstein
1,575 Reputation
9 Guides authored
Cal Poly, Team 17-6, Forte Spring 2015 Member of Cal Poly, Team 17-6, Forte Spring 2015
CPSU-FORTE-S15S17G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 276
