Introduction
If your controller(s) malfunction, you can replace the circuit boards. You only need a Phillips #1 screwdriver.
Parts
No parts required.
  1. With the controller on its face, remove the five 6 mm Phillips #1 screws. After removing the screws, carefully lift the controller casing . After removing the screws, carefully lift the controller casing .
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  3. Pinch the top and bottom of the shoulder buttons and lift them out. Below each shoulder button, there are small elastic pads.  To remove them,  pinch the pads and slide them out. Removing the elastic pads allows easier circuit board access.
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  4. Carefully lift the circuit board from the controller case. Carefully lift the circuit board from the controller case. Carefully lift the circuit board from the controller case.
    • Carefully lift the circuit board from the controller case.
Evelyn
223 Reputation
2 Guides authored
USF Tampa, Team S4-G4, Eyestone Fall 2017 Member of USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 180
