Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
The upper case assembly includes the keyboard. Use this guide to replace the entire case/keyboard assembly as a single unit.
To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable. These accessories are not included with your MacBook, so make sure you have them ready before you begin.
    • Before proceeding, unplug and power down your MacBook. Close the display and flip it upside-down.
    • 2015 models only: To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  1. Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges. Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case. Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  2. While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  3. Lift the upper case and display together from the front edge and raise it to about a 45˚ angle. It may be helpful to prop the MacBook open in this position for the next step.
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    This step at the suggested height tears the ribbon cable. do step 7 first. carefully
    Kiernan - Reply
  4. Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button. If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds. If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  5. Close the MacBook and carefully flip it upside-down.
    • Close the MacBook and carefully flip it upside-down.
  6. Lifting from the front edge, open the lower case to an angle of about 45°.
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Before the IPD flex cable can be removed the battery disconnect button has be held down for up to 10 seconds. If the LED near the battery connector is switched on it shows that there is power going through the logic board from the battery, once the button is pressed and this light goes off the machine is safe to be worked on.
    Aaron Dalziel - Reply
  7. Use tweezers to peel back the tape covering the trackpad cable ZIF connector. Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  8. Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector. Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    This is very tricky indeed - at least on my computer. I failed at this point - having skipped to it as sugested above so as not to stress the ribbons on the other side. The ZIF was not as I expected. They had opened when I pulled up the stick cover and I found I was working on the socket itself. The top edge came adrift after almost no pressure being put on it. The ribon did not come free with gentle pulling though. At that point I put the back on again… waited until the battery recharged a bit and found I had not nroken it after all. I doubt I shall try again. It is much harder to replace than the 15 inch - much…
    Simon Anthony - Reply
    I’ve just found that I have broken it after all. No keyboard. Bluetooth still works so I can use the machine.
    All in all, an expensive mistake. BTW - I did NOT get the kit from IFIXIT - not sold here.
  9. Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame. Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  10. Carefully turn the MacBook over, so that the lower case lays flat. Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Carefully turn the MacBook over, so that the lower case lays flat.
    • Raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  11. Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board. 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    • 2015 models have a silver grounding clip with two foam pads directly under this screw, which may come loose. Be sure to reinstall it during reassembly.
    the moment you opening macbook case and before any tinkering with connections, you MUST press little yellow button on logicboard, located on the right from battery connector - this will disable all power to the board. You can check by looking at the small led on left side of the battery connector - if there is very faint light, it means that power is still there. After pressing button light should go off. Removing screw is not necessary at all, and like I said - you MUST disable power before any touching to connections etc.
    DigiHead - Reply
  12. As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector. As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  13. Remove the two screws securing the USB-C port cable bracket:
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Tri-point Y00 screw
    • 3.5 mm T5 Torx screw
    On the 2016 model the tri-point Y00 is actually a Phillips screw, so need of that special tool.
    Chavdar Christov - Reply
    The 2015 model has the Phillips—PH000
    jay - Reply
  14. Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board. To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  15. Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector. Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  16. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  17. Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so that the side with the white stripe faces you, as shown.
    hey my macbook do not have sound after replacing the topcase, i did connect everything like here you did, also I did the reset of PR and NVRAM. What Can I check more? simply when I open the OS, there is no audio device at all
    dkflu - Reply
  18. Use tweezers to peel back the tape covering the display cable connector. Use tweezers to peel back the tape covering the display cable connector.
    • Use tweezers to peel back the tape covering the display cable connector.
  19. It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape. If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  20. Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If it doesn't separate easily, heat the cable and/or the case directly beneath it with a hair dryer or iOpener to soften the adhesive, and try again.
  21. Disconnect the display cable by gently pulling it straight out of its connector.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap.
    • The flap must remain closed when the cable is reinserted during reassembly. Carefully line up the cable with the gold contacts facing down, and gently slide it into the connector. Take care not to crimp or damage the cable. When fully inserted, the indentations on the sides should not be visible.
  22. Separate the upper case assembly from the lower case assembly.
    • Separate the upper case assembly from the lower case assembly.
  23. Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable. Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    Does unplugging the "dual microphone assembly ribbon cable" affect anything other than the microphones? The headphone jack is separate, for example, right?
    wizfish mcfrabblegabben - Reply
    Right. We haven't tested it, but unplugging that cable shouldn't affect anything other than the microphones. You can see the microphone assembly in this guide.
    Jeff Suovanen -
  24. Use tweezers to pull the  microphone assembly ribbon cable free of its connector. Use tweezers to pull the  microphone assembly ribbon cable free of its connector.
    • Use tweezers to pull the microphone assembly ribbon cable free of its connector.
    I broke the microphone assembly ribbon cable, from step twenty five. Is there anyway to fix this, soldering kit, or can I order a new cable online?
    Read Fuller - Reply
  25. Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
  26. Remove the audio jack board.
    • Remove the audio jack board.
  27. Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
    • Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
    If you are replacing the case upper case check to see if your replacement case has a microphone assembly included. If it does you can skip 28-30
    Marco Romani - Reply
  28. Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case. Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case. Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
    • Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
    very difficult to remove, even with heat. Can be purchased on eBay for ~ $10
    zimmerninja - Reply
  29. Remove the dual microphone assembly.
    • Remove the dual microphone assembly.
    During reassembly, do you need to apply adhesive to the microphone assembly to glue it back to the case? What adhesive is the best to use?
    Andrei - Reply
    Usually with a part like this, the replacement comes with adhesive pre-applied—just peel off the liner and stick it in place. If you’re re-using the old microphone, you might be able to get away with heating it up a little using a heat gun or hair dryer to soften the old adhesive, and then stick it down. Failing that, I’d add a little B7000 adhesive.
    Jeff Suovanen -
  30. Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
    • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
  31. Remove the single 4.3 mm Phillips #00 screw securing the USB-C port ribbon cable.
    • Remove the single 4.3 mm Phillips #00 screw securing the USB-C port ribbon cable.
  32. Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath. Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath. Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath.
    • Unfold the USB-C port ribbon cable until it lays flat, allowing access to the bracket beneath.
    On the 2016 model the USB-C is actually one whole part and can be removed once the display is removed, unfortuanatelly.
  33. Lift and remove the metal bracket securing the USB-C port ribbon cable connector.
    • Lift and remove the metal bracket securing the USB-C port ribbon cable connector.
    • During reassembly, be sure the metal tab on the USB-C connector board slides through the slit on the metal bracket.
  34. Use a spudger to disconnect the USB-C port ribbon cable by prying the connector straight up. Pry from the side nearest the back edge of the MacBook. Remove the ribbon cable.
    • Use a spudger to disconnect the USB-C port ribbon cable by prying the connector straight up.
    • Pry from the side nearest the back edge of the MacBook.
    • Remove the ribbon cable.
  35. Fully open the display.
    • Fully open the display.
    • Set the MacBook down on its right edge with the display facing away from you, as shown.
  36. Remove the four 4.8 mm T8 Torx screws securing the display hinges. Remove the four 4.8 mm T8 Torx screws securing the display hinges.
    • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
  37. Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case. There are only a few millimeters of play between the hinges and the case, so you won't need to push far. Push the upper case forward while pulling back gently on the display.
    • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
    • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
    • Push the upper case forward while pulling back gently on the display.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    There is a small metal part that falls off once the display cable screws are removed and you try to separate the display from the top cover. Just make sure you put it back correctly.
  38. Remove the single 2.9 mm T3 Torx screw securing the USB-C port to the upper case.
    • Remove the single 2.9 mm T3 Torx screw securing the USB-C port to the upper case.
    this was a 00 philips on my 1.1ghz 2015 gold macbook.
    zimmerninja - Reply
  39. Slide the USB-C port out of its recess in the upper case, and remove the USB-C port. Slide the USB-C port out of its recess in the upper case, and remove the USB-C port. Slide the USB-C port out of its recess in the upper case, and remove the USB-C port.
    • Slide the USB-C port out of its recess in the upper case, and remove the USB-C port.
  40. Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad. Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad.
    • Use a pair of tweezers to remove the tape covering the keyboard ribbon cable connector on the trackpad.
  41. Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector. Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector.
    • Using a spudger, flip open the retaining flap on the keyboard ribbon cable ZIF connector.
  42. Gently pull the keyboard ribbon cable out of its slot in the frame. Gently pull the keyboard ribbon cable out of its slot in the frame.
    • Gently pull the keyboard ribbon cable out of its slot in the frame.
  43. Remove the five 2.5 mm T3 Torx screws securing the trackpad to the case.
    • Remove the five 2.5 mm T3 Torx screws securing the trackpad to the case.
    • Depending on which bit set you use, a T4 driver may fit better. Try both sizes, and use the largest driver that fits fully into the screw head.
  44. Remove the trackpad assembly.
    • Remove the trackpad assembly.
    • Metal brackets on each side of the trackpad may fall away during removal. Be sure to position them as shown in the photo during reassembly.
  45. Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF connector. Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF connector.
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF connector.
  46. Gently peel the keyboard ribbon cable up from the case, and remove the cable. Gently peel the keyboard ribbon cable up from the case, and remove the cable. Gently peel the keyboard ribbon cable up from the case, and remove the cable.
    • Gently peel the keyboard ribbon cable up from the case, and remove the cable.
  47. The upper case remains.
    • The upper case remains.
    Great guide!!! Thank you!!! It is not very difficult to replace the keyboard / top cover. However, for some reason the computer didn’t immediately started, I had to reset and connect to power supply and then it started and works fine.
To reassemble your device, follow these instructions in reverse order. To avoid logic board damage, when your MacBook repair is complete but before powering it on, connect it to low-voltage power using a 5-Watt iPhone charger and a USB-C to USB-A cable.
14 other people completed this guide.
Geoff Wacker
79,790 Reputation
89 Guides authored
3 Comments
please where do i have to put the mushrooms screws? 923-01012
Antonio gaeta - Reply
If you look closely at this image in Step 36 you can see them pretty clearly.
Jeff Suovanen -
I changed the keyboard itself; you follow the instructions to step 35 (skipping 29 to 30, microphone removal) and then remove the keyboard ribbon cable connector to the trackpad (step 45). Maybe the most complicated step is ungluing the black backing stuck to the back of the keyboard and then there are almost a hundred tiny screws holding the keyboard to the frame, mostly only an eye strain. Got the keyboard through ebay (spanish keyboard layout).
Lorenzo Segovia - Reply
Past 24 Hours: 7
Past 7 Days: 59
Past 30 Days: 240
All Time: 18,876
