Battery Replacement on an Asus Q524U
  1. Battery Replacement on an Asus Q524U, Remove back plate of computer: step 1, image 1 of 3 Battery Replacement on an Asus Q524U, Remove back plate of computer: step 1, image 2 of 3 Battery Replacement on an Asus Q524U, Remove back plate of computer: step 1, image 3 of 3
    • Remove all 10 screws from the backplate of the computer using a Torx T5 screwdriver.
    • Make sure to keep all screws in a safe place, they are small and it is very easy to lose track of them.
  2. Battery Replacement on an Asus Q524U, Use prying tool to help separate back plate: step 2, image 1 of 2 Battery Replacement on an Asus Q524U, Use prying tool to help separate back plate: step 2, image 2 of 2
    • Use the prying tool to help maneuver and separate the back plate off of the computer safely. This will expose important hardware and internal parts.
  3. Battery Replacement on an Asus Q524U, Remove the silver bridge restricting the battery by lifting tabs: step 3, image 1 of 1
    • Pull lightly on the blue tabs until the silver bridge is safely free.
    • Once the bridge is removed the battery is then accessible.
  4. Battery Replacement on an Asus Q524U, Remove screws from battery bracket: step 4, image 1 of 1
    • Get a #00 Philips head screwdriver ready for use.
    • Carefully remove the #00 Philips screws to release the battery from the computer.
  5. Battery Replacement on an Asus Q524U, Disconnect battery from circuit board: step 5, image 1 of 1
    • Locate the connector for the computer battery and circuit board.
    • Carefully pull up on the connection to safely disconnect the battery.
  6. Battery Replacement on an Asus Q524U, Replace battery and reassemble computer: step 6, image 1 of 1
    • Carefully replace with a new battery and reassemble the computer with all previously used screws.
Furthermore, this is a comprehensive guide for a battery replacement on an Asus Q524U personal computer. To reassemble your device, please follow these instructions in reverse order.
3 other people completed this guide.
Zachary Franz
214 Reputation
1 Guide authored
3 Comments
Thanks.
How long a battery should last?
And how long daily without charging?
I'm sorry but i have never had a laptop in my life.
I'll appreciate your help.
Andrea Redeker - Reply
Hello I want to ask. I’m trying to replace the battery and im at the part with the blue strip for the Silver bridge part is out how do I put it back on?
Devon Jones - Reply
How did you determine you had to replace the battery. My green charging light won’t turn on and I’ve replaced the charger, but still nothing. Could this be due to a bad battery?
dwkestell - Reply
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 45
All Time: 4,829
