This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
The pinion gear on the electric brush can wear out, causing the brush to stop spinning.
Turn the device over and remove all screws.
Remove the white cover
Remove the inner cover. To do this, carefully loosen the cover and then pull it out to the right so as not to damage the fiber-optic cables.
Disconnect the gearbox from the circuit board and remove it.
If you want to replace the complete gearbox, you can install the replacement part now
Remove the rubber damper.
Heat the upper part of the gearbox with a heat gun until the cover can be pried off using a spatula or similar tool.
Then remove the green pinion gear and replace it with a new one.
Follow the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
41%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
