Shop the Holiday Gift Guide
Replacing the DeLonghi EN 550.S Latissima Touch brewing unit
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
53
Past 30 Days:
213
All Time:
2,156
Comments: 3
3 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
If a significant amount of water and coffee ends up directly in the capsule container instead of in the cup, you should check the brewing unit. Thorough cleaning may help, otherwise you will need to replace it.
Tools
    1. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Preparations: step 1, image 1 of 1
      • Never forget: Unplug the machine before starting repairs.
      • Remove all attachments such as the water tank, milk tank, and capsule drawers.
      Ask FixBot
    2. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the back cover: step 2, image 1 of 2 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the back cover: step 2, image 2 of 2
      • Turn the device over so that the back is facing you.
      • Remove the four Phillips screws.
      • Remove the back cover; it may be a little stuck.
      Ask FixBot
    3. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the right side panel: step 3, image 1 of 3 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the right side panel: step 3, image 2 of 3 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the right side panel: step 3, image 3 of 3
      • Pull the right side panel back by about 1cm and remove it
      Ask FixBot
    4. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Unscrew the top cover: step 4, image 1 of 2 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Unscrew the top cover: step 4, image 2 of 2
      • The top cover is secured with a Phillips screw under the side panel. Unscrew that screw.
      • Push the cap behind the lever for the brewing unit back about 1 cm and remove it.
      Ask FixBot
    5. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the top cover: step 5, image 1 of 2 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Remove the top cover: step 5, image 2 of 2
      • The top cover is still connected to the motherboard by a ribbon cable.
      • The connection is fragile! If the connector is too tight in the socket, it can tear off the board. This will damage the board!
      • Bend the two tabs on the sides of the connector to the side using a small flat screwdriver.
      • Use a suitable tool, e.g., small needle-nose pliers. Be extremely careful when pulling the connector toward you. Work slowly and patiently.
      Ask FixBot
    6. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit: step 6, image 1 of 2 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit: step 6, image 2 of 2
      • Press the top cover firmly toward the front and lift it over the lever of the brewing unit
      • When reassembling, make sure that the pin on the power button fits into the opening on the gray plastic part.
      Ask FixBot
    1. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Replace the brewing unit: step 7, image 1 of 2 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit, Replace the brewing unit: step 7, image 2 of 2
      • Pull out the metal clamp on the pressure hose to the brewing unit using needle nose pliers
      • Pull out the pressure hose
      Ask FixBot
    2. Replacing the DeLonghi EN 550.S Latissima Touch brewing unit: step 8, image 1 of 3 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit: step 8, image 2 of 3 Replacing the DeLonghi EN 550.S Latissima Touch brewing unit: step 8, image 3 of 3
      • There are two Phillips screws on each side of the brewing unit. Remove those.
      • Lift the brewing unit out.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Author
with
VauWeh
346,390 Reputation
317 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
45 Members
7,070 Guides authored
3 Guide Comments
Habe den Kapselhebel abgebrochen, wahrscheinlich zu fest gedrückt. Ist das die passende BrühGruppe für DeLonghi EN550.B Brühgruppe (Infuser/Piston Assembly) inklusive Hebel?
https://www.ebay.de/itm/283878750819?shp...
Peter - Reply Share
@peter30937 Der Metallhebel? Ja klar, der ist daran befestigt, so wie auf den Fotos zu sehen.
VauWeh - Reply Share
Ja, habe mittlerweile die Brüh-Einheit ganz ausgetauscht. Deine Anleitung war sehr hilfreich. Vielen Dank
Peter - Reply Share
Past 24 Hours: 4
Past 7 Days: 53
Past 30 Days: 213
All Time: 2,156
