Replacing a Jeans Button
  1. Replacing a Jeans Button, Button: step 1, image 1 of 3 Replacing a Jeans Button, Button: step 1, image 2 of 3 Replacing a Jeans Button, Button: step 1, image 3 of 3
    • Lay your jeans front-side up on a sturdy table or workbench.
    • Unzip the fly and open the jeans at the waistband to reveal the hole where the button is missing.
    • Hold the waistband at the hole and turn it over, so you can see the back of the hole.
    • Be sure to fully remove the old button before installing a new button.
  2. Replacing a Jeans Button: step 2, image 1 of 3 Replacing a Jeans Button: step 2, image 2 of 3 Replacing a Jeans Button: step 2, image 3 of 3
    • Insert the tack into the back of the hole.
    • Push the tack through the hole.
    • If the hole is too large, you can make a new, smaller hole for the tack in an undamaged section of the denim as close the existing hole as possible. Then push the tack through the new hole.
  3. Replacing a Jeans Button: step 3, image 1 of 3 Replacing a Jeans Button: step 3, image 2 of 3 Replacing a Jeans Button: step 3, image 3 of 3
    • Holding the tack in place from behind, place the button on top of the tack.
  4. Replacing a Jeans Button: step 4, image 1 of 3 Replacing a Jeans Button: step 4, image 2 of 3 Replacing a Jeans Button: step 4, image 3 of 3
    • Place a flat work surface like a scrap piece of wood or a cutting board directly beneath the tack and between the front and back of the jeans.
    • Be sure to use a small (one pound) hammer or mallet to prevent breaking the button.
    • Hammer the button onto the tack, with a straight downward pound.
    • If you’re uncomfortable holding the button with your fingers while you hammer, you can use a pair of pliers to hold the button in place.
  5. Replacing a Jeans Button: step 5, image 1 of 1
    • Test out your new button by buttoning the jeans to ensure the new button is set and secure.
Brittany McCrigler
89,014 Reputation
131 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,816 Guides authored
Past 24 Hours: 138
Past 7 Days: 1,016
Past 30 Days: 4,532
All Time: 468,817
