Replacement de la vitre tactile et de l'écran LCD du Samsung Galaxy Note8
    • Insérer un commentaire.
Finish Line
21 other people completed this guide.
ian mdx
8,968 Reputation
17 Guides authored
9 Comments
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Reply
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Reply
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Reply
Will the phone remain waterproof after this repair?
cj-dm - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 24,037
