Introduction
This Guide (with the prerequisites) covers Screen removal and replacement on the Why! NK50SZ.
It is advisable to read through all the steps before you begin; if you get ahead of the instructions you may take a premature (and potentially damaging) action.
Unlock the right latch and hold the left latch unlocked with your finger.
While holding the left latch, lift the battery from the slot under the right latch.
Remove the two screws (red circles).
Partially straighten a paperclip. (or use an appropriate tool if you have one.)
Insert the improvised tool into the orifice (red arrow) marked by the icon (red square)
Insert the paperclip into the orifice to unlock the keyboard preparatory to removing it in the next step.
Lift the keyboard, without removing it.
Locate the ribbon cable attaching it to the motherboard. (red rectangle)
After you open the latch, remove the cable (red arrow).
Now you can remove the keyboard.
You must unscrew the six screws (red circles) and disconnect remove the fan lead.
The assembly can now be carefully lifted out.
Disconnect the three ribbon cables (orange rectangles)
Remove the five screws (red circles)
Insert a pick between the edges of the upper and lower case and slide it as depicted.
Continue with the pick to disengage the plastic 'clips' along both sides.
Remove the Bottom cover.
Position the device keyboard down and peel off the adhesive strip (orange square).
Disconnect the cables (orange square) and remove the three screws (red circles).
Disconnect the cable (orange square). Then peel off the adhesive (Yellow rectangle). Disentangle the leads from their routing.
Now you can remove the right speaker (red square)
Disconnect the cable (orange rectangle) and remove the left speaker (red rectangle)
Disconnect the cable (orange rectangle) and remove the two screws (red circles)
Remove the screw (red circle) and disconnect the ribbon cable (orange circle).
Unscrew the three screws (red circles) and remove the big black plastic part.
Unscrew the screws (red circles).
Remove the Black plastic part (as the red arrows direct) photo one.
Lift the metal part (orange rectangle)
Remove the three screws (red circles) and remove the black plastic part.
Lift the metal piece (orange rectangle), unlatch the cable connector (green rectangle) and remove the adhesive-backed 'tape' (yellow rectangle).
disconnect the cable (orange circle) secured by the adhesive tape.
Remove the top Cover
Insert a pick into the bottom edge of the frame and slide it as depicted. (red arrows)
Avoiding force, carefully unclip the lower part by hand.
Heat the upper part of the frame with a hair dryer to weaken (soften) the adhesive tape beneath.
Insert the pick under the top edge of the frame, slide it as depicted.
Remove the screen frame.
Unscrew the six screws (red squares), as well as the two (red circles).
Remove the hinges
Run a hair dryer around the edges of the cover, as indicated by the red arrows.
Carefully lift to remove the screen
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
