Replace the Light Socket in a Desk Lamp
    1. Replace the Light Socket in a Desk Lamp, Light socket: step 1, image 1 of 3 Replace the Light Socket in a Desk Lamp, Light socket: step 1, image 2 of 3 Replace the Light Socket in a Desk Lamp, Light socket: step 1, image 3 of 3
      • Unplug the lamp before starting to avoid electrical shock.
      • Carefully unscrew the bulb by turning it counterclockwise.
      • If it’s tight, use a cloth for better grip and protection.
      • Set the bulb aside in a safe spot.
      Ask FixBot
    2. Replace the Light Socket in a Desk Lamp: step 2, image 1 of 3 Replace the Light Socket in a Desk Lamp: step 2, image 2 of 3 Replace the Light Socket in a Desk Lamp: step 2, image 3 of 3
      • Grip the harp saddle firmly and lift it straight up to release it from the socket base.
      • Some lamps have clips or tension that hold the saddle in place—if yours does, gently squeeze the sides to loosen it.
      • Set the saddle aside for reassembly later.
      Ask FixBot
    3. Replace the Light Socket in a Desk Lamp: step 3, image 1 of 2 Replace the Light Socket in a Desk Lamp: step 3, image 2 of 2
      • Turn the light switch handle counterclockwise to remove it.
      • Some handles may be snug, so take your time and avoid forcing it.
      Ask FixBot
    4. Replace the Light Socket in a Desk Lamp: step 4, image 1 of 3 Replace the Light Socket in a Desk Lamp: step 4, image 2 of 3 Replace the Light Socket in a Desk Lamp: step 4, image 3 of 3
      • Gently pull the socket shell up from the lamp base.
      • Some sockets may be snug or clipped in. If so, gently wiggle the socket while pulling to loosen it.
      • Be careful not to pull too hard on the wires—they are still connected underneath.
      Ask FixBot
    5. Replace the Light Socket in a Desk Lamp: step 5, image 1 of 3 Replace the Light Socket in a Desk Lamp: step 5, image 2 of 3 Replace the Light Socket in a Desk Lamp: step 5, image 3 of 3
      • Carefully open the inner socket housing to access the wire connections.
      • Depending on your lamp model, you may need to unscrew the socket, release a locking tab, or separate a snap-fit joint.
      • Use a screwdriver to loosen the terminal screws or clips and gently disconnect the wires.
      Ask FixBot
    6. Replace the Light Socket in a Desk Lamp: step 6, image 1 of 2 Replace the Light Socket in a Desk Lamp: step 6, image 2 of 2
      • Release the wire by loosening screws, releasing clips, or pulling them from push-in connectors, depending on the socket.
      • Take note of how the wires were connected for reassembly later.
      Ask FixBot
    7. Replace the Light Socket in a Desk Lamp: step 7, image 1 of 3 Replace the Light Socket in a Desk Lamp: step 7, image 2 of 3 Replace the Light Socket in a Desk Lamp: step 7, image 3 of 3
      • Align the new socket with the metal brackets or prongs on the lamp base, then secure it.
      • Depending on the lamp, snap it into place, twist to lock, or fasten it with screws.
      • Make sure the socket sits firmly and evenly to prevent wobbling.
      Ask FixBot
    8. Replace the Light Socket in a Desk Lamp: step 8, image 1 of 3 Replace the Light Socket in a Desk Lamp: step 8, image 2 of 3 Replace the Light Socket in a Desk Lamp: step 8, image 3 of 3
      • Press the socket cap down onto the base until it clicks or locks into place.
      • If it has screws, replace and tighten them to secure the socket.
      • Reattach the harp.
      • Finally, screw in a working bulb and test the lamp to confirm the repair was successful.
      Ask FixBot
Phieu Pham
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 85
All Time: 534
