Replace the Bosch Verocafe coffee spout
  1. Replace the Bosch Verocafe coffee spout, Bosch Verocafe coffee spout: step 1, image 1 of 2 Replace the Bosch Verocafe coffee spout, Bosch Verocafe coffee spout: step 1, image 2 of 2
    • The front panel is just snapped in place. Insert a suitable tool into the gap and carefully pry off the panel.
  2. Replace the Bosch Verocafe coffee spout: step 2, image 1 of 2 Replace the Bosch Verocafe coffee spout: step 2, image 2 of 2
    • There is a retainer above the coffee spout. It is attached at the top with two pins (red circles) and at the bottom by two delicate plastic tabs.
    • First, pull the two top pins from their holes.
    • Then very carefully pull (and lift) out the holder together with the coffee spout at the bottom. The plastic tabs are fragile.
  3. Replace the Bosch Verocafe coffee spout: step 3, image 1 of 2 Replace the Bosch Verocafe coffee spout: step 3, image 2 of 2
    • Remove the retainer from the coffee spout.
    • Pull off the silicone hose.
    • Pull the metal sleeves off the outlet nozzles.
    • Now you can try flushing the coffee spout or replace it entirely.
Reverse the steps to reassemble your device.
Special thanks to these translators:
de en
100%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
304,314 Reputation
303 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 64
All Time: 1,094
