This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
As the plug of the dust container lid has broken off, I need to replace the lid. This is very easy to do. All you need is a plastic spatula or slotted screwdriver and a little care when removing the broken lid.
As you can see, the plug on the lid, which was still attached, broke off - so the vacuum cleaner is no longer easy to use. I fixed it provisionally with some adhesive tape, but it didn't last long, because when I emptied the dust container, dust got stuck to the adhesive tape again...
To do this, press the black ribbed buttons and simply remove the battery.
Next, you should remove the dust filter. You already know this step if you use the vacuum cleaner normally. Simply give it a little twist and take it out.
Take a spatula or slotted screwdriver and carefully lever the lid out of its holder on one side. The plastic is quite flexible and should give way enough for you to get the lid out on one side. Then it's already done.
Now insert the new cover. It should snap into place with a little pressure. Again, first on one side - then the other.
That's it. Enjoy! ;)
Special thanks to these translators:
91%
Moritz is helping us fix the world! Want to contribute?
Start translating ›
