Replace Front Panel
  1. Replace Front Panel, Battery: step 1, image 1 of 2 Replace Front Panel, Battery: step 1, image 2 of 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Replace Front Panel: step 2, image 1 of 3 Replace Front Panel: step 2, image 2 of 3 Replace Front Panel: step 2, image 3 of 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Replace Front Panel, Front Panel: step 3, image 1 of 2 Replace Front Panel, Front Panel: step 3, image 2 of 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Replace Front Panel: step 4, image 1 of 3 Replace Front Panel: step 4, image 2 of 3 Replace Front Panel: step 4, image 3 of 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Replace Front Panel: step 5, image 1 of 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
You Zhou
343 Reputation
2 Guides authored
IUPUI, Team 3-1, Baechle Fall 2016 Member of IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 383
