Shop the Holiday Gift Guide
Repairing the left click of a Logitech Performance MX mouse
Views: 27K
View statistics:
Past 24 Hours:
9
Past 7 Days:
60
Past 30 Days:
347
All Time:
26,660
Comments: 9
9 guide comments.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓
After a long time, the left mouse click can become unreliable sometimes. This results in unintentional double-clicks or drag-and-drops. This can be fixed by disassembling the mouse and bending a certain metal part.
Thanks to Kyler’s Studio for the tutorial I initially followed.
Tools
    1. Repairing the left click of a Logitech Performance MX mouse, Turn off the mouse and remove the battery: step 1, image 1 of 1
      • Remove the battery.
      Ask FixBot
    2. Repairing the left click of a Logitech Performance MX mouse, Remove the 3 pads: step 2, image 1 of 1
      • The pads (or soles) are made of two layers. Ideally, the two should remain bonded together, but this is difficult to achieve.
      Ask FixBot
    3. Repairing the left click of a Logitech Performance MX mouse, Remove the 4 screws from the bottom of the mouse: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the four screws (indicated by red circles) that hold the bottom of the mouse.
      Ask FixBot
    4. Repairing the left click of a Logitech Performance MX mouse, Lift the top of the mouse: step 4, image 1 of 3 Repairing the left click of a Logitech Performance MX mouse, Lift the top of the mouse: step 4, image 2 of 3 Repairing the left click of a Logitech Performance MX mouse, Lift the top of the mouse: step 4, image 3 of 3
      • Remove the bottom by lifting the top of the mouse. Sliding sideways won't help, but gripping the base at the front in the gap between the button ends and the base, or using a guitar pick on the sides to unclip the top from the base, will work.
      Ask FixBot
    5. Repairing the left click of a Logitech Performance MX mouse, Remove the connector: step 5, image 1 of 1
      • You can disconnect (unplug) the two parts of the mouse using tweezers. This isn't necessary, but it makes the repair process easier.
      Ask FixBot
    6. Repairing the left click of a Logitech Performance MX mouse, Put a little adhesive tape on the multiswitch: step 6, image 1 of 1
      • You can put some tape on the top of the micro-switch, which prevents losing the white piece.
      Ask FixBot
    7. Repairing the left click of a Logitech Performance MX mouse, Remove the top of the multiswitch: step 7, image 1 of 2 Repairing the left click of a Logitech Performance MX mouse, Remove the top of the multiswitch: step 7, image 2 of 2
      • Use your spudger to push the vertical front part of the micro-switch outwards (forward and up relative to the mouse) to unlatch and release the top part of the switch casing.
      Ask FixBot
    8. Repairing the left click of a Logitech Performance MX mouse, Flatten the metal part: step 8, image 1 of 2 Repairing the left click of a Logitech Performance MX mouse, Flatten the metal part: step 8, image 2 of 2
      • Flatten the metal part of the microswitch (it will probably be curved upward) until you get a clearer "click" sound.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
12 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Samuel Colin
755 Reputation
2 Guides authored
9 Guide Comments
merci , ca vient de sauver ma Revolution
Clement Renaut - Reply Share
Avec plaisir. J'en suis ravi :)
Samuel Colin - Reply Share
Thank you, this worked flawlessly. Your time and effort is well appreciated.
Kenji Lum - Reply Share
Thank you so much. My left click often unregisters incorrectly. If not for step 7 and 8, I wouldn't have opened the multiswitch top and clean the contact point. Seems to work perfectly normal now. It'd be a waste to throw away the whole item just because of a tiny defective component. Thanks again for helping me fixed it.
Thuan Chau - Reply Share
@Kenji @thuan: I'm glad I could help. Thanks for your comments!
Past 24 Hours: 9
Past 7 Days: 60
Past 30 Days: 347
All Time: 26,660
