Repairing a Papier-mâché Mask
  1. Repairing a Papier-mâché Mask, Repairing a Papier-mâché Mask: step 1, image 1 of 2 Repairing a Papier-mâché Mask, Repairing a Papier-mâché Mask: step 1, image 2 of 2
    • Carefully look over the mask and find the damaged area.
    • Make sure the mask is clean, dry, and dusted before you start the repair.
    • Take a moment and try to understand the full damage of the mask, this will help you approach the repair more properly.
    Ask FixBot
  2. Repairing a Papier-mâché Mask: step 2, image 1 of 2 Repairing a Papier-mâché Mask: step 2, image 2 of 2
    • Cut papier-mâché strips long enough to fully cover the damaged area and gap.
    • Prepare at least two or three strips beforehand so you can work quickly.
    • Cutting the strips beforehand will keep the process more clean and controlled.
    Ask FixBot
  3. Repairing a Papier-mâché Mask: step 3, image 1 of 2 Repairing a Papier-mâché Mask: step 3, image 2 of 2
    • Once that piece is cut, dip it into hot water until the piece is fully wet.
    • Let it soak until it becomes fully saturated.
    • Then take it the piece out of the water and be ready to place it on the damaged area.
    • The strip should feel soft, but workable before using it.
    Ask FixBot
  4. Repairing a Papier-mâché Mask: step 4, image 1 of 2 Repairing a Papier-mâché Mask: step 4, image 2 of 2
    • Lay the now damp strip across the gap.
    • Press it into place, and make sure it bridges the whole gap.
    • Smooth the strip with your fingers to blend it into the mask’s surface.
    • Make sure to take your time here, this first layer is what creates the foundation of the repair, and overall shape of the mask in that area.
    Ask FixBot
  5. Repairing a Papier-mâché Mask: step 5, image 1 of 2 Repairing a Papier-mâché Mask: step 5, image 2 of 2
    • Repeat the process with two or three more strips.
    • Layer them over the damaged area to create the thickness and strength of the repair.
    • Press/shape the layers so they follow the original shape of the mask before it was damaged.
    • Smooth any bumps or raised edges to help create a more seamless repair
    • You’re essentially rebuilding the mask, so make sure it feels solid and even.
    Ask FixBot
  6. Repairing a Papier-mâché Mask: step 6, image 1 of 2 Repairing a Papier-mâché Mask: step 6, image 2 of 2
    • Let the repaired area dry for at least 10–12 hours.
    • Once fully dry, apply the acrylic paint with the accompanying brush, and use them to blend the repaired section into the mask.
    • Wait for the paint dry for at least 3–5 hours.
    • Once dry and painted, your mask should feel fully ready to use again!
    Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 34
All Time: 57
