Fix Your Stuff
Right to Repair
Parts & Tools
Introduction
This guide describes how to fix the H02/H07 error that is common with Panasonic DVD/VCR players.
Parts
No parts specified.
  1. With the front display of the device facing you, rotate the device 90 degrees counter clockwise. Remove the screw that is on the right side of the panel facing you. Now rotate the device 180 degrees and remove the second screw.
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Remove the screw that is on the right side of the panel facing you.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove all screws with a phillips head screwdriver.
  2. Rotate the device so that the back faces you. With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
    • Rotate the device so that the back faces you.
    • With a phillips head screwdriver, locate and remove the two screws highlighted by the red circles in image one.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Before removing top cover make sure that the back of the device is facing you.
    • Before removing top cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  5. Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Note that the spindle you will be lubing is located underneath the white disk device highlighted in figure one
    • Tilt the device on its front side until you can see underneath the white circular component mentioned in the note above.
    • Locate the spindle circled in figure two and apply one or two drops of 3 in 1 lubricating oil to the spindle.
Nathan Cheadle
137 Reputation
7 Guides authored
Cal Poly, Team 16-5, Maness Spring 2010 Member of Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Members
7 Guides authored
2 Comments
Thanks you saved my Christmas and nailed this as my wife loves Christmas music in the background for our family dinner. Thanks again and Merry Christmas
Jerry Wayock - Reply
I have a Panasonic NV-SD235 and I have a tape stuck with the error H02.
Mark Zarraonandia - Reply
Past 24 Hours: 8
Past 7 Days: 33
Past 30 Days: 127
All Time: 24,216
