Introduction
This guide will teach you how to replace the Sony Cyber-shot DSC-W290's LCD screen.
Find the hatch labeled "open" on the left side of the bottom of the camera.
Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
Remove the four 2.5mm Phillips #0 screws.
Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
Rotate the LCD and its casing so that the screen is facing you.
Gently pull the control panel downward, freeing it from the small metal clips.
Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
3 other people completed this guide.
