1. Before disassembly, make sure that the device is unplugged.
    • Before disassembly, make sure that the device is unplugged.
    • Unscrew the two 17.83 mm black screws located on the handle.
  2. Separate the shell from the main component.
    • Separate the shell from the main component.
    • Make sure that the each piece is free from debris.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Continue to pull the components apart. For reassembly, put the silver encasing on before the the black cover. For reassembly, put the silver encasing on before the the black cover.
    • Continue to pull the components apart.
    • For reassembly, put the silver encasing on before the the black cover.
  5. Locate the switches in the handle of the device.
    • Locate the switches in the handle of the device.
  6. Set the multimeter to 200 ACV.
    • Set the multimeter to 200 ACV.
  7. Bring the probes toward each switch to test for continuity.
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a finite number, the circuit is open and the switch needs to be replaced.
    • To replace faulty switch, cut the wires and solder the wires back on to the new switch.
Jessica Leyva
107 Reputation
5 Guides authored
Cal Poly, Team 1-5, Propen Fall 2012 Member of Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 878
