RIDGID R84015 X2 Planetary Gear Replacement Guide
  1. RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: step 1, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide, RIDGID R84015 X2 Case Removal: step 1, image 2 of 2
    • Remove the backplate.
    • Using a Torx T20 screwdriver, remove the four screws attaching the back plate.
  2. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 2, image 1 of 1
    • Remove the drill handle.
    • Using the Phillips #2 screwdriver, remove the five screws attaching the drill handle to the body.
  3. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 3, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 3, image 2 of 2
    • Remove the gear casing from the body.
    • Using the Philips #2 screwdriver, remove the four screws attaching the gear casing to the body.
  4. RIDGID R84015 X2 Planetary Gear Replacement Guide, Planetary Gear: step 4, image 1 of 1
    • Prepare to remove the gear chamber.
    • Using the Phillips #2 screwdriver, unscrew the four screws at the rear of the plastic gear chamber.
  5. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 5, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 5, image 2 of 2
    • Remove the motor from the drill by gently pulling the motor away from the gear chamber.
    • NOTE: Handle the gear chamber with caution as the gears are now loose.
  6. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 6, image 1 of 1
    • Remove the plastic gear chamber.
    • Using the Phillips #2 screwdriver, remove the four screws that attach the plastic gear chamber.
  7. RIDGID R84015 X2 Planetary Gear Replacement Guide: step 7, image 1 of 2 RIDGID R84015 X2 Planetary Gear Replacement Guide: step 7, image 2 of 2
    • Remove each component from the gear assembly. Replace components as needed.
    • Reassemble the drill following the gear replacement instructions in reverse order.
Finish Line
4 other people completed this guide.
Evan Long
262 Reputation
4 Guides authored
Cal Poly, Team 15-48, Garner Spring 2010 Member of Cal Poly, Team 15-48, Garner Spring 2010
CPSU-GARNER-S10S15G48
6 Members
10 Guides authored
One Comment
Very helpful, thank you! I was not sure how to detach the motor from the gearbox and didn't want to apply any brute force, and this explained it well.
YURIY - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 12
All Time: 6,217
