Introduction
This guide will help you replace the upper casing on your device. Following these steps will also enable you to replace the camera.
Parts
No parts required.
Remove the four rubber-like pieces from all corners of the surrounding area that border the screen.
  • Remove the four rubber-like pieces from all corners of the surrounding area that border the screen.
Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
  • Be sure that you do not strip or damage the screws.
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Carefully pry the screen open using a plastic spudger.
  • Carefully pry the screen open using a plastic spudger.
  • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
Take the screen housing off from the casing. Watch for small pieces falling out from the screen during this step. Keep track of these pieces. Watch for small pieces falling out from the screen during this step. Keep track of these pieces.
  • Take the screen housing off from the casing.
  • Watch for small pieces falling out from the screen during this step. Keep track of these pieces.
4 other people completed this guide.
krisko
95 Reputation
4 Guides authored
Cal Poly, Team 11-4, Forte Winter 2010 Member of Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 4,879
