Introduction
This guide will show you how to remove and replace the screen for a Motorola V3c.
Parts
No parts required.
  1. Remove the four rubber pieces from all corners of the area that borders the screen.
    • Remove the four rubber pieces from all corners of the area that borders the screen.
  2. Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  3. Spread Fixmas Cheer
    Get $12 off your purchase of $50 or more with code FIXMAS12
    Spread Fixmas Cheer
    • Pry screen cover off with plastic spudger.
    • The screen cover has some adhesive holding it to the screen
    • Remove small black sticker covering the camera ribbon connector.
    • Flip over small hinge that covers the camera ribbon connection.
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
    • Disconnect the metallic ribbon cover.
    • Remove and replace the screen.
Finish Line
Joshua Ruehlig
503 Reputation
4 Guides authored
Cal Poly, Team 11-4, Forte Winter 2010 Member of Cal Poly, Team 11-4, Forte Winter 2010
CPSU-FORTE-W10S11G4
3 Members
8 Guides authored
One Comment
Is it a T5 or a T4 for removing the screws?
Francis Reyes - Reply
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 17
All Time: 8,971
