Introduction
How to replace a microwave turntable motor.
Unplug the microwave and turn it upside down.
  • Unplug the microwave and turn it upside down.
Instead of removing every screw to access the turntable motor I decided to just make myself an access door. This should have been built in by the manufacturer but it wasn't. I used a dremel cut off wheel and trimmed these 6 little bits off the case.
  • Instead of removing every screw to access the turntable motor I decided to just make myself an access door. This should have been built in by the manufacturer but it wasn't. I used a dremel cut off wheel and trimmed these 6 little bits off the case.
Carefully swing your new access door open. Be careful there can be really sharp edges. Here the motor has already been removed.
  • Carefully swing your new access door open. Be careful there can be really sharp edges. Here the motor has already been removed.
I ordered a replacement motor and had it on hand. Simply unplug the old one and install the new one. If the microwave is upside down the connecting gear should be  viewable once the motor has been popped straight up and out. The gear was visible in the picture showing the access door.
  • I ordered a replacement motor and had it on hand. Simply unplug the old one and install the new one. If the microwave is upside down the connecting gear should be viewable once the motor has been popped straight up and out. The gear was visible in the picture showing the access door.
I decided to open up the old motor to see how it worked. I could not see anything wrong with the old motor. I secured the access door back down to the microwave by using an existing screw and a washer.
  • I decided to open up the old motor to see how it worked. I could not see anything wrong with the old motor. I secured the access door back down to the microwave by using an existing screw and a washer.
oguitar200
193 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 975
