Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
Component teardown of Gateway 420GR desktop. This machine originally shipped with Windows XP.
This teardown is not a repair guide. To repair your Gateway 420GR, use our service manual.
  1. The left panel of the case has thumbscrews that release the left side from the case.
    • The left panel of the case has thumbscrews that release the left side from the case.
  2. Loosen the first thumbscrew
    • Loosen the first thumbscrew
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Loosen the second thumbscrew.
    • Loosen the second thumbscrew.
  5. The side panel will now slide toward the back of the case.
    • The side panel will now slide toward the back of the case.
  6. System RAM
    • System RAM
    • USB headers for front panel USB ports.
    • CMOS battery
  7. Pair one RAM retention clips.  There are two (one on each end) for each of the available slots.
    • Pair one RAM retention clips. There are two (one on each end) for each of the available slots.
    • Pair two RAM retention clips. There are two (one on each end) for each of the available slots.
    • RAM should be paired (same size) and the machine support up to 4GB or RAM as 1GB modules in each of the 4 slots.
    • System supported RAM is 184-pin DIMM DDR PC3200
kyle23
182 Reputation
1 Guide authored
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 2,620
