Introduction
Actualiza la memoria RAM en tu MacBook Pro 13 "Unibody a mediados de 2012.
Extrae los siguientes diez tornillos:
Tres tornillos Phillips #00 de 14.4 mm
Tres tornillos Phillips #00 de 3.5 mm
Cuatro tornillos de resalto Phillips #00 de 3.5 mm
Usa el borde de un spudger para levantar el conector de la batería haciendo palanca para extraer su toma de corriente de la placa madre.
Prying the battery connector off does not take much force. I did exactly what the guide suggested (walked it off back and forth) with the spudger without any problems. Just be very gentle, much like with anything inside laptops, they are very fragile and need to be worked with carefully. A+ instructions, battery replacement was a success.
Be patient on disconnecting this one. It worked for me step by step, little by little.
I used the nails of thumb and pointer finger simultaneously - worked pretty fine
I whittled down ends of two wooden strips to use, along with my fingernails to start with. I used halves of a wooden clothespin, but popsicle sticks should work too.
Dobla el cabre de la batería ligeramente para alejarlo de su conexión en la placa madre para evitar que se conecte accidentalmente mientras trabajas.
I put some tape between the connector and socket while working on the drive.
That's a good tip
Anrothan -
Great tip, I did that too
One other note: The screw heads fit flush with the curvature of the case -- which means that they aren't exactly horizontal. In other words, they aren't perpendicular to the table that the computer is resting on. Don't try to force them straight in vertically, because you'll risk cross-threading them. (nearly ruined one screw hole myself!)
On my MacBook Pro, the connector seems to be an integral part of the battery.
I suspect it’s just like the special screwdriver required for seatbelts on cars – to discourage regular consumers from attempting repairs. Of course, this only encourages consumers to use the wrong tool to attempt to repairs
Dissambling my MacBookPro Premium Mid 2012 (i5-3210M 2.5Ghz) was easily, Careful with the screws, use screwdriver fitting exactly with the screws, you damage them very fast. Work very exactly, relaxed with time, consentration, good Tools and with feelings in your hands. Disconnect the Akku was easy if you take care, remove it to be safe, Two screws more, more space to work & haven`t to think about damaging someting. Apple use diffrent screws, you should have many difffrent scewdrivers. It is also good to clean everything inside, With time everything gets very dusty & dirty, don`t forget the sides and little fittings at the case. Use a pinsel, alcohol, soft peace stuff, it will look like new. If you have knowledge & experience, you can paint it in any colour or airbrushing for individualizing. You can also just polish it with a soft Politure (Sonax car Polish No1, NOT with wax or take an other light Politure you familiar & can do the job, A Laptop should serviced once a year, keeping it good working over years
First thing i do is open & cleanig everything inside,specially the cooling & fan, renew the thermal paste with an high quality product. Install the Nain System, clean up Bloatware and other unnecessary things, install standard software for daily use, additional change system components against better one (Edge to Firefox, Windows Media Player to VLC , an Office Suite and configuring everything for Data Protection, Privacy- & Indentety Protection, install Drivers from the component Manufactur (incedible effect, disable limitations, more functions, work better & faster, increasing performance, additional change the WiFi & Bluetooth Card to a better one a UMTS WWAN to an LTE Card, increase RAM with two Dual-Channel working SODIMMs, Use M2 or 2,5" SSD if no M2 Slot aviable) as System- and Software iDrive, a FAT32 formatted 32GB Partition to be safe of metaviruses comes with harmless downloads, and a big 2,5 HDD to store the user data. What does you guys think about this? Old Computer become a new life,
I livein Austria, near Vienna, if someone needs help or anything else, i would be glad to help. I always searching old or broken devices to bring them to new live. I also searching for spare parts, specilly a Bottom & Side Case and a 256GB or higher NGFF Storage Card for a Sony Vaio Tab 11 SVT1144HE (2014), some 14,1" Displays for a HP Probook 440G5 (2016), Elitebook MT 43 Mobile Thin Client, (2011), Dell Vostro 3460 (2012) Lenovo Thinkpad T440s (2014), and a Logic Board for an Lenovo Ideapad 330-15ARR (2017, damaged by Water i think) and a Logic Bord for an Alienware 17R4 with i7-6870HX & Nvidia 1080 (2018, CPU dead, maybe there is a repair Guide or workaround to bring it back to Life). I need always 8GB or 16GB DDR3 and DDR4 RAM Storage (perfectly two ident one for Dual-Channel use for Laptops, M2 SATA 6GB/s and NVMe PCIe SSDs 500GB or more and 2,5"SSD or HDD with 1TB or more and 3,5" HDD with 4GB or above. If you have some of this or other useful parts and doesn`t need them, please make me an offer, maybe
2
an change something you need. This is not a Business what i do, it`s more a Hobby with challenging new Excercices.. Thats the best Point. Plase forgive me as a Newbie this very long Post in the wrong Section, but if you are start writing you cannot stop.... But now i have to come to an end and would be happy if someone wants to get in contact. My E-Mail is: udontknowme@gmx.at (the adress name is just a notice against Big Data and for Privacy Protection!
Tira de los dos brazos de retención de RAM alejándolos del centro del chip RAM.
Tira de la palanca de memoria RAM fuera de su zócalo.
After replacing the RAM my macbook did not start anymore. Only if I take out one Ram it works. Does anyone knows why.
Hello Joelcroese, have you a issue about your problem, because i have actually this problem ? ... Thanks for your feed back.
Make sure both your RAM chips are running at the same speed - don't know about the Macbook but it will cause other machines to not recognize the RAM at all or only pick up one stick -
Is the channel configuration of your ram sticks correct? Mac needs 9-9-9-24 channel configuration. Something like Corsair Mac Memory or the kit that iFixit provides are in the correct channel configuration.
Thank you, Phillip! I have now (just recently) used FOUR of your guides—1) HARD-DRIVE replacement, 2) hard-drive CABLE replacement, 3) BATTERY replacement, and 4) RAM upgrade installation—to successfully refurbish my daughter’s late-2011, 13.3-inch MacBook Pro and, thereby, hopefully, add a few more years to its useful life. Thanks, again!
Sincerely,
Garrick de Demeter
Does the MacBook Pro 13“ (mid 2012) accept a bundle of 2x 8GB RAM to make it run with 16GB? Because the Apple Support page says „maximum 8GB“. Does that only mean the standard configuration, or does it mean the mainboard can only handle 8GB (2x4GB) not 16 GB (2x 8GB)?
Do you have an answer for this? I have 8GB originally and would love to upgrade.
Para volver a montar tu dispositivo, sigue estas instrucciones en orden inverso.
590 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
43 Comments
Just replaced my 4GB with 16GB of PNY from Best Buy. AWESOME difference in performance!!
Could you please specify the memory chip that you bought? I need more details in order to get the right one, thanks!
Lin -
Any memory kit that is either validated by Apple or that has the proper channel configuration (9-9-9-24) is okay to use. If you are looking for pure performance RAM, a kit of Corsair Vengeance RAM is okay to use (again, check the channel configuration), but most people will benefit from a kit of Corsair Mac Memory or the kit that iFixit provides in the volume of your choice.
IThis great I actually added 16GB ram into mine. I purchased from bestbuy. Got a great deal! They price match!
7 December 2015: Successfully used this guide on my new BTO Mid 2012 i7 13" - really nice to have this tutorial up on my iMac while I did this - nice to "check off" the steps.
I remembered from somewhere that one at least used to have to reset the PRAM/SMC, but, it recognized the new RAM amount of 16 glorious GB with no problem.
I think disconnecting the battery had the same effect, as the Date reverted not quite to 1969 - that also updated with no problem.
Thanks!
I just changed out my RAM chip with 8 GB chip bought from you. It was very easy with your guide to follow. The employes I talked with were very knowledgable and helpful. Thank you
Je viens d'installer mes deux barrettes de G.Skill 4GOx2 en remplacement des mes barrettes ELPIDA d'origine. Merci à IFixit pour ce tutoriel très clair, j'ai mis une heure au total (30 minutes de montage et 30 minutes de nettoyage après 6 ans et demi!). Je suis très satisfait de ce tuto. Thanks IFixit!
My mid-2012 13” says it has 4GB RAM and I want to upgrade to 8GB. Do I need to get 2 X 4GB or just 1 X 8GB? If I get just 1 X 8GB can I leave the old RAM in the 2nd slot?
Either 2 X 4GB or 1 X 8GB will work, but not one of each. Whenever you install multiple RAM sticks in a machine they should be exactly the same manufacturer and model. So if you wanted to upgrade from 4GB to 8GB you should either buy another identical 4GB stick and install it alongside the original, or remove the original and buy either two new 4GB sticks or one 8GB stick. Either choice will effectively provide the same result. Hope this helps!
Sam Omiotek seems to be wrong here. You can mix ram. It’s not the most performance or optimal way, but that’s it. You can do it.
Buying 2 identical RAM dices will give you up to 15% speed boost for apps that need all of it - music/video/graphic design.
You can buy 1x8GB and replace one of the older rams in your machine for a total of 2+8 ram and it will work just fine.
owca -
Salve. Ho installato questa mattina l’espansione di memoria Ram da 16 GB (2x8) sul MacBook Pro Unibody da 13", versione metà 2012.
Crucial CT2KIT102464BF160B Kit Memoria da 16 GB (8 GBx2), DDR3L, 1600 MT/s, PC3L-12800, SODIMM, 204-Pin. Totale EUR 136,99
FANTASTICO!!! Un’altra macchina!!!…Acqusito da fare assolutamente.
what is the maximum RAM can be installed in macbook pro 13” mid 2012? is 2x8GB the maximum?
16GB in the 2 X 8GB configuration is the maximum supported, and it’s worth it if you’re using Garage Band, iMovie, Photoshop, etc…
I just upgraded my Mid-2012 Non-Retina MBP (2.9GHz i7, 750GB@5400RPM) from 2x 4GB DDR3-1600 to 2x 8GB DDR3-1600. So far it works flawlessly and I am about to upgrade the hard drive in it to a 1TB SSD. I am installing Crucial memory and their MX500 SSD.
Well, it’s 2019 and I just did this to my old 2012. It was quite easy. Reading comments I realized the main concern regarding disconnecting the battery is to avoid frying the motherboard by accidentally touching areas with something conductive and I agree.
The first re-boot showed only one bay in use and I had to check and found out I didn’t push the top memory card hard enough but once I fix this hiccup and re-booted again I saw the new 16gb and my loving MacBook Pro comes to life so fast!
I just upgraded my RAM from 4GB to 16, and I don’t even recognize this computer. The difference in performance is so off the charts it’s like having a new computer. I’d intentionally gone for an older model because there certain components I needed to work remotely, and had been really regretting my decision. Now the only thing I’m upset about is how long I waited. Thank you for the clear and detailed guide on how to do this.
So i got my 2 8 GB ram and installed it in 5 minutes. Laptop runs very fast now like its nearly new. Thank you ifixit. Next up is battery, then hard drive. Going to save up for those two.
Way to go! I use the 15” version of this machine at work with 16GB ram and a SSD. It’s nine years old and still truckin’!
Merci pour cette aide à l’installation des barrettes mémoire très explicite et bien documentée par les photos. Parfait !
Bien fait! Vous avez un bon ordinateur.
ram done today, easy and better performance with 16 gb , two 8 gb sticks, much better then four.
next week , ssd to be replaced , buy a tool remove fan and clean same time.
thank you very much, the instructional videos .
ive just replaced my old 2x4gb with 2x8gb (16gb) and my mac is now making a very hight pitched but quiet background noise, im guessing from the power draw or something? is theyre anyway to make this stop?
I can’t be certain but it could be coil whine. See if it sounds like this. If it is in fact coil whine the best you can do is reinstall the RAM and see if that fixes it. If not, request a replacement from customer service and see if that fixes it. Good luck!
2021 Jan. 30: I just installed 2 x 8GB RAM (16GB total) in my 13” mid-2012 MacBook Pro (“MBP”), to replace the 2 x 2GB RAM that came in it. An apple tech (“Advisor”) told me that his tech notes at Apple say that my MBP does support 16GB RAM, and after a few minutes of testing with the new RAM, the MBP works significantly faster (from a little bit, to lots, depending on the app or function) :-)
I bought the 2 new 8GB RAM modules/”sticks” that I installed from Best Buy, and they are PNY brand, model #MN8GSD31600LV (DDR3, 1600MHz, 1.35V, CAS 11), at $40 each ($80 + tax, total).
Dear Madam, dear Sir, I followed the apple tutorial to change the ram of my early2011 Macbookpro.Unlike in iFixit tuto, it is not specified to disconnect the battery prior RAM removal/installation. Now the machine does not start, even if I replace the old ram.
Mac does not react anymore, magsafe is not even recognised
I already tried the SMC reset using shift+ctrl+option + power 10s , unfortunately it did not work.
Is there any trick?
I had to proceed to dust removal, do you believe I generated some shortcuts somewhere or the fact that I removed the ram without disconnecting battery is the main issue?
I solved the issue: Opened again the mac. Disconnected the battery. connected the magsafe charger. restart mac. close the mac without stop it. wait the fan stop. reconnect the battery. Connect the magsafe, now it works back as before
We’re glad it works! In the future, we recommend following our guides. We always instruct to disconnect the battery as soon as possible during upgrades or repairs to prevent damage.
Just upgraded by 4GB to 16GB RAM with the toolkit I bought from iFixit.
It was my first ever Mac repair/upgrade, but thanks to the detailed step-by-step guide and the repair kit it went like a breeze.
very happy with the result, next is upgrading my old HDD with SSD
All going nicely but the clip on one side snapped off. RAM sill clipped in fine and looks secure. Anything needs to be done?
A gauche, la charnière en haut, il est un peu difficile de distinguer entre le rouge et l(orange foncé. Il vaudrait mieux des couleurs bien dissemblables.
fait en 1/4 d’heure sans se presser et en mimant chaque geste avant. C’est la première fois que je touche un MacBookPro mi 2012.
Does anyone know if it is required to be DDR3L? Or will DDR3 work as well?
It’s my understanding that the “L” denotes that it is a lower voltage variant, but I wasn’t sure if that was a deal breaker or not as I have 2x4GB DDR3 modules from another system that I would like to use instead of buying new (if possible).
Hey Hi! The below space for the second module doesn't work on my MacBook from mi 2012. I've got only one module working and i would like to know if i can change the part with the 2 Space, the entire RAM port?
Thanks for your answer and letting us repair our own goods with those awesome tutorials ! ;)
Merci Fabienne & Claire. C'est génial quand ça fonctionne !! Mon macbook pro 13" mi 2012 est reparti pour de belles aventures...
Avec plaisir :) Et bravo à vous pour la réparation !
I'm not a tech-savvy person in the slightest, but my other laptop has to go into for repairs next week, and it will take 2 weeks, so I need a computer. This literally took 5 minutes and was so easy.
I replace my Mid-2012 macbook pro's 4 GB with 16 GB, its a 10 year old laptop and I have restored it to factory settings, so it's got nothing on it anymore. But now it doesn't just pinwheel every time I try to open google chrome or excel at the same time.
Just make sure that before closing the lower case, reconnect the battery, I mean you'll figure it out pretty quickly, but you unscrewing and re-screwing all those screws is a little annoying, not like I know first hand or anything.....
i don't have a spudger. what other things can i use to pry the battery?
How much weight can I save by removing the optical drive?
gunes314 - Reply
You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
Marshall WahlstromHelgren -
Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
Robert Wacker - Reply
Hello, where can I buy the screws I need in case I lose one of them?
taylornya - Reply
iFixit sells a kit: MacBook Pro Unibody Lower Case Screw Set
Darrell Johnson -
I have one stripped screw... How opening without drill it?! Any suggestions please?
rodrigosady - Reply
I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
Michael Wilkens -
We have a guide for that!
How to Remove a Stripped Screw
Sam Omiotek -
My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
jeremyyoung - Reply
A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
Iain Boyd - Reply
I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
cam2000deluxe -
Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
Patrick Langvardt - Reply
That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
Gary Register -
Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
Degeorges - Reply
Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
Claire Miesch -
Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
Moritz - Reply
Funny, it's not her hands that are doing the close ups. :)
Cinemated Man - Reply
What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
MLNLRD - Reply
