Introduction
If your display shows dots or stripes, or if it is cracked, use this tutorial to "replace a cracked screen" Samsung Galaxy A51 (SM-A515F / DS) , you can buy a new screen by clicking here.
"Before opening up your phone, it's recommended to use up the battery of the Samsung Galaxy A51 to get it below 25%. In case you damage the battery while fixing it, the risks of it catching fire or exploding will decrease if the battery is lower."
"Important:" The screen replacement requires you to take off the screen on the back of the phone, so you will need replacement adhesive of some kind to re-attach the back screen onto the phone.
Heat up the back screen of the phone for about 5 minutes at a temperature 65°C to be able to remove it.
Insert a plastic card between the back glass and the metallic contour and slide it all around the phone.
Heat the glass multiple times during this procedure in order to soften the adhesive.
Remove your new display from its box and take off the protective stickers.
'''Put some B7000 glue on the perimeter of the display frame before repositioning it.'''
Attach the display to its frame and do not forget to thread its connection cable through the hole provided for this purpose.
Connect the display cable to its connector located just next to the headphone jack.
After receiving your new screen, you will need to take off the protective films covering it before being able to install it.
"Tip:" Turn your phone on and test your repair before installing the new adhesive and closing the phone.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
