Introduction
You need to disconnect or replace the ventirad of your Dell XPS 13 9380, this guide is for you!
Use a Torx T5 driver to unscrew the eight screws securing the back panel.
Use a spudger to pry up and loosen the back panel.
Lift the back panel up slightly from the non-hinged edge.
Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
When the back panel clips are free, remove the back panel.
Disconnect the cable from the battery by pulling the connector towards the battery.
Remove the four screws (M2 x 2) securing the battery.
Remove the screw (M1.6 x 4) securing the battery.
Remove the battery from its recess.
1- Remove the 4 screws (M2x3) that attach the ventirad to the motherboard.
2- Lift the ventirad and remove it from the motherboard.
To reassemble your device, follow the instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
100%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
