This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Introduction
Utiliser ce guide pour remplacer le ventilateur sur le Dell XPS 13 9350
Utiliser une pincette pour retirer le petit connecteur blanc en le tirant vers l'extérieur et en l'éloignant de sa prise.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
5 other people completed this guide.
Special thanks to these translators:
75%
Schwarzer is helping us fix the world! Want to contribute?
Start translating ›
3 Comments
Great guide! The two hardest parts were getting the back cover off, and lifting the motherboard to remove the fan. Took me about 30 minutes in total.
It would be really easier if you remove the battery screws first… there are some steps that were not clear…
This repair took me about 45 min for a complete novice. “Walking out” the battery connector was only way I could unplug it. There was a retaining bracket overlaying the flat connector (step 8) that I needed to unscrew (2 screws, phillips) before it could be removed. Take care to replace the wire in the wire guides along the fan’s housing prior to reinsertion of the replacement fan. It cannot be done afterwards and the back panel will not be flush. Otherwise, this was an excellent guide and an easy repair.
