Remplacement du panneau arrière sur Dell XPS 13 9380
  1. Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: step 1, image 1 of 3 Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: step 1, image 2 of 3 Remplacement du panneau arrière sur Dell XPS 13 9380, Retirer le panneau arrière: step 1, image 3 of 3
    • Dévisser les huit vis (Torx M2x3) qui fixent le panneau arrière.
    • Retournez l’ordinateur, puis ouvrez-le en l’inclinant.
    • À l'aide d'un Spudger, faites levier sur le panneau arrière.
    • En faisant glisser le panneau arrière de gauche à droite, libérez les clips qui le fixent. Vous pouvez ainsi le retirer.
    You should be careful when removing the back panel as there also two clips on its back where the air ducts lie. If you are quick to remove it you may tear the air ducts which are quite (unreasonably) fragile given the fact they are plastic. I was unfortunate and I broke two of them so I had to use some duct tape as a minor gap would be visible between the back panel and the plastically covered air ducts. Other than that, it’s a pain to remove the back panel but not as difficult as it sounds.
    Iraklis - Reply
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
Schwarzer
4,844 Reputation
13 Guides authored
i.Fixit FR Team Member of i.Fixit FR Team
Community
3 Members
40 Guides authored
One Comment
The torx bit used is a T5, the screw is an m2x3 — if you’re buying a kit you want the T5 torx bit
swosse - Reply
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 54
All Time: 4,426
