Ouvrez les mâchoires du mandrin au plus grand diamètre. Retirez la vis à l'intérieur du mandrin à l'aide d'un tournevis Torx T20.
Retirez le mandrin de la perceuse.
Vérifiez si le mandrin ou le support de mandrin ont des défauts ou sont encombrés.
Si vous remplacez le mandrin, fixez un nouveau mandrin et vérifiez qu'il fonctionne.
Si vous enlevez les débris d'un bourrage, assurez-vous que le support du mandrin est dégagé avant de réinstaller le mandrin et de vérifier qu'il fonctionne.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
5 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
7 Comments
I agree with Jan. This does not make sense to me and i have been twisting this stupid thing for 3 days.
Your comment ‘The chuck screw is reverse threaded, which means you will need to unscrew it counterclockwise. ‘ is nonsense.
A normal screw is counterclockwise to unscrew.
What you meant to say was
‘The chuck screw is reverse threaded, which means you will need to unscrew it clockwise. ‘
You might also like to add the the screw is often coated with loctite and very difficult to remove. A high quality tool and plenty of force may be required to remove this screw.
I think the clockwise thing wasn’t that hard to understand, but personally, my chuck screw was actually quite easy to remove so it wasn’t a problem for me
J .Healy -
https://studio.youtube.com/video/Vx37F9q...
Here’s a short video on how to fix a chuck on drill. The screw that holds the chuck to the drill broke and needed to be extracted, and replaced.
