Introduction
Guide pré-requis pour remplacer le bouton Home de votre iPhone 5s.
Veuillez noter que la fonction Touch ID pourra être utilisée uniquement par les téléphones avec le bouton Home original. Un nouveau bouton Home inclura seulement les fonctions ordinaires Home, mais pas la Touch ID.
Dévissez l'unique vis captive Phillips #000 qui fixe le câble du bouton home.
Pour remonter votre appareil, suivez ce tutoriel dans le sens inverse.
35 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
6 Comments
Unfortunately this will never work, the sensor is paired to the logic board. If you want to replace the defective tactile switch, remove all the plastic/rubber parts on the flex cable and resolder a new switch or disassemble the switch and clean/replace the metal dome switch. If you want to repair fingerprint function, just give up.
I purchased a full iphone 5S home button replacement assembly (comes with the home button attached to the flex cable) And now the fingerprint function does not show up at all. Where it's supposed to show in settings as "Touch ID and Passcode" It only says passcode. Restored as new to 7.1, still doing the same thing.. Anybody have ideas?
Only the home button that came with the phone has Touch ID function. In order to replace it and still have Touch ID, you would need to get it replaced at an Apple Store.
p3rs0nn -
I think you can easily break the Touch ID sensor
