Introduction
Utilisez ce tutoriel pour remplacer le ventilateur.
N'oubliez pas de suivre notre |744|tutoriel sur l'application de la pâte thermique|new_window=true] avant de réinstaller votre dissipateur de chaleur.
Ôtez les dix vis suivantes, qui fixent le boîtier inférieur au boîtier supérieur :
Deux vis Pentalobe P5 de 2,3 mm
Huit vis Pentalobe P5 de 3,0 mm
Retirez délicatement la protection en caoutchouc du ventilateur, qui se trouve sur le bord du dissipateur thermique.
Utilisez la pointe d'un spudger pour pousser de chaque côté du connecteur de la nappe de la caméra iSight pour le faire sortir de sa prise sur la carte mère.
Pour remonter votre appareil, veuillez suivre les instructions dans l'order inverse.
82 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
17 Comments
Very good instructions, just completed the fan replacement, no issues -
Fantastic instructions, brilliant depictions for assistance. Thank you!
I completed this guide and it was brilliant, so thank you Andrew Optimus Goldberg and your contributors! I have a question about the Macbook's heat post-installation of a new fan.
I replaced the fan last night, and put everything back together. Today, the new fan is responding well under activities that would previously make the fan extremely loud and cause intense heat to build up on the bottom right of the Macbook: so far so good.
However, it seems heat is now being distributed to the keys and directly below the screen, and I can even feel it underneath the trackpad, and this is from simply turning the Macbook on with no applications straining the CPU.
Is this something to worry about? Have I possibly made a mistake in my installation, or is this normal for an ordinary working fan?
Thanks for any help that may be given. Appreciated
Is the fan you replaced the original one with the exact same model? While im no expert on this stuff my guess would be that it distributes air differently. I hope it works out for you though.
Nikolay -
Just completed the fan replacement. Great clear instructions. No issues. Thank you so much.
