Introduction
Suivez les différentes étapes de ce tutoriel pour retirer ou remplacer les vis Pentalobe d'un iPhone 7.
Éteignez votre iPhone avant de commencer le démontage.
Retirez les deux vis Pentalobe de 3,4 mm qui se situent sur le bord inférieur de l'iPhone.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
53 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
5 Comments
are there any water seals associated with the pentalobe screws? I blew compressed air into my iphone 7 and two tiny square rubber gaskets (~3mm) popped out. They squares have a round hole in them. I can only figure they are part of the pentalobe screw water seals, but I’m not sure, and I don’t know how to put them back in the phone to restore the water seal. Can anyone offer a solution?
@ataterka The screws themselves have a tiny ring-shaped rubber gasket on them. The two rubber squares you found slip onto the screw bosses. I don’t think those are needed for water sealing, and they’re not even included on newer models.
Does iPhone 7 and iPhone 8 (including «Plus» models) share the same bottom pentelope screws?
Put new lcd on with no problems then later batter went bad got new battery and can not get the 2 pentathlon screws out they loosen but not come out will tighten back up lossen but still want come out
How do I get screws out
