Introduction
Après un certain temps, l'autonomie d'une batterie rechargée commence à baisser. Ce tutoriel vous montre comment enlever la coque arrière de la tablette afin d'accéder à la batterie et de la remplacer.
Utilisez le petit spudger métallique pour créer un espace entre la coque arrière et le reste de l'appareil en-haut de la fente de la carte mémoire.
Utilisez le spudger métallique intermédiaire à la place du petit spudger métallique pour enlever la coque arrière. Cela se fait en glissant le spudger métallique intermédiaire le long du périmètre de l'appareil, en commençant en-haut de l'emplacement de la carte mémoire.
La deuxième image montre la partie interne de l'appareil une fois que la coque arrière est enlevée.
Pour réassembler votre appareil, suivez ces instructions dans l'ordre inverse.
87 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
30 Comments
Thank you so much !
please help us
The Tab A of my son we dont know what happen they shut down we can not open it.
but the charger is ok but we try to chargers the device is not open it.
The Tab A is 7 mounths using only thats why we are worried what happen.
Please help thanks,
My 10.1" died suddenly - never dropped, shocked - worked fine in the morning, wouldn't come on two hours later. Won't take a charge or show ANY sign of life. 53 weeks old and maybe 10 hour use a week. I can't seem to open it without making a mess out of it. I was impressed by the product when it was working - certainly NOT impressed anymore. A very shiny and expensive paperweight.
Long time since you posted this, but clean out the micro USB charge port. Use a toothpick gently, and vacuum. A lot of lint and dirt gets in and stops a proper connection
i looked everywhere online for a simple guide with pics for tab a and all i found was tab 2 and up so THANK YOU SO MUCH !!!!!!
