Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Removing the DeLonghi EN 550.S Lattissima Touch inner top cover
View statistics:
Past 24 Hours:
5
Past 7 Days:
23
Past 30 Days:
96
All Time:
559
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
To reach many of the internal components, you must remove the inner top cover. The mainboard is attached to it. You will gain access to the heater, the pump, and other important components.
Tools
    1. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Preparations: step 1, image 1 of 1
      • Never forget: Unplug the machine before starting repairs.
      • Remove all attachments such as the water tank, milk tank, and capsule drawers.
      Ask FixBot
    2. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the back cover: step 2, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the back cover: step 2, image 2 of 2
      • Turn the device over so that the back is facing you.
      • Remove the four Phillips screws.
      • Remove the back cover; it may be a little stuck.
      Ask FixBot
    3. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the right side panel: step 3, image 1 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the right side panel: step 3, image 2 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the right side panel: step 3, image 3 of 3
      • Pull the right side panel back by about 1cm and remove it
      Ask FixBot
    4. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Unscrew the top cover: step 4, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Unscrew the top cover: step 4, image 2 of 2
      • The top cover is secured with a Phillips screw under the side panel. Unscrew that screw.
      • Push the cap behind the lever for the brewing unit back about 1 cm and remove it.
      Ask FixBot
    5. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the top cover: step 5, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Remove the top cover: step 5, image 2 of 2
      • The top cover is still connected to the motherboard by a ribbon cable.
      • The connection is fragile! If the connector is too tight in the socket, it can tear off the board. This will damage the board!
      • Bend the two tabs on the sides of the connector to the side using a small flat screwdriver.
      • Use a suitable tool, e.g., small needle-nose pliers. Be extremely careful when pulling the connector toward you. Work slowly and patiently.
      Ask FixBot
    6. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 6, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 6, image 2 of 2
      • Press the top cover firmly toward the front and lift it over the lever of the brewing unit
      • When reassembling, make sure that the pin on the power button fits into the opening on the gray plastic part.
      Ask FixBot
    1. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Replace the brewing unit: step 7, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Replace the brewing unit: step 7, image 2 of 2
      • Pull out the metal clamp on the pressure hose to the brewing unit using needle nose pliers
      • Pull out the pressure hose
      Ask FixBot
    2. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 8, image 1 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 8, image 2 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 8, image 3 of 3
      • There are two Phillips screws on each side of the brewing unit. Remove those.
      • Lift the brewing unit out.
      Ask FixBot
    1. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Preparation: step 9, image 1 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Preparation: step 9, image 2 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover, Preparation: step 9, image 3 of 3
      • Push the left side panel toward the water tank and lift it out.
      • Take a photo of the connections on the logic board, then disconnect them.
      • Unthread the wire harness from the logic board.
      Ask FixBot
    2. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 10, image 1 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 10, image 2 of 3 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 10, image 3 of 3
      • The inner top cover is held in place by several clips. Use a small flathead screwdriver to help release the clips.
      • Lift the inner top cover up and out.
      Ask FixBot
    3. Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 11, image 1 of 2 Removing the DeLonghi EN 550.S Lattissima Touch inner top cover: step 11, image 2 of 2
      • The inner top cover contains the motherboard, which you can now remove.
      Ask FixBot
Follow these steps in reverse order to reassemble your device.
Author
with
VauWeh
347,842 Reputation
321 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
46 Members
7,130 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 96
All Time: 559
