Removing the Cover From the Printer
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Removing the Cover From the Printer, Top Cover: step 1, image 1 of 1
    • Remove the back two 14.0 mm Torx #10 screws.
  2. Removing the Cover From the Printer: step 2, image 1 of 1
    • Lay the printer on its back.
    • Grab the paper tray by its right side and pull it to the left and up.
  3. Removing the Cover From the Printer: step 3, image 1 of 1
    • Open the frontal access panel by lifting it from the top.
    • Similar to the paper tray, grab it from the right side and pull it to the left and up.
  4. Removing the Cover From the Printer: step 4, image 1 of 3 Removing the Cover From the Printer: step 4, image 2 of 3 Removing the Cover From the Printer: step 4, image 3 of 3
    • Take out the two frontal 14.0 mm Torx #10 screws.
    • Carefully lift the frontal cover.
    • Don't lift it up aggressively. A strip will be attached to it.
Justin Taiki Fukada
891 Reputation
7 Guides authored
Cal Poly, Team 1-41, Maness Winter 2014 Member of Cal Poly, Team 1-41, Maness Winter 2014
CPSU-MANESS-W14S1G41
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 29
