Magellan RoadMate 1200 Back Cover Replacement
  1. Magellan RoadMate 1200 Back Cover Replacement, Back Cover: step 1, image 1 of 2 Magellan RoadMate 1200 Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Remove the four rubber caps from the back by using the Phillips #00 screwdriver.
  2. Magellan RoadMate 1200 Back Cover Replacement: step 2, image 1 of 1
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Magellan RoadMate 1200 Back Cover Replacement: step 3, image 1 of 2 Magellan RoadMate 1200 Back Cover Replacement: step 3, image 2 of 2
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover—the speaker is screwed onto the back cover and is connected to the circuit board.
  4. Magellan RoadMate 1200 Back Cover Replacement: step 4, image 1 of 2 Magellan RoadMate 1200 Back Cover Replacement: step 4, image 2 of 2
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
2 other people completed this guide.
Ross Light
217 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 3,467
