Removing Dell Inspiron 530 Processor
  1. Removing Dell Inspiron 530 Processor, Side Panel: step 1, image 1 of 1
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Removing Dell Inspiron 530 Processor: step 2, image 1 of 1
    • Slide the side panel towards the back and remove.
  3. Removing Dell Inspiron 530 Processor, Removing Processor: step 3, image 1 of 1
    • Locate the processor's heat sink and fan.
  4. Removing Dell Inspiron 530 Processor: step 4, image 1 of 1
    • Remove the fan's power cable from the motherboard.
  5. Removing Dell Inspiron 530 Processor: step 5, image 1 of 1
    • Locate and unscrew the four Phillips #0 screws at the corners of the fan.
    • The screws will not come out completely.
  6. Removing Dell Inspiron 530 Processor: step 6, image 1 of 1
    • Remove the fan and heat sink.
  7. Removing Dell Inspiron 530 Processor: step 7, image 1 of 1
    • Gently press down and release the silver lever.
  8. Removing Dell Inspiron 530 Processor: step 8, image 1 of 1
    • Open the metal casing over the processor.
  9. Removing Dell Inspiron 530 Processor: step 9, image 1 of 1
    • Gently lift up the processor, holding by the edges only.
Note: For reassembly on step seven, make sure the corner of the processor with the gold triangle is pointing towards the release lever.
14 other people completed this guide.
James Aldag
402 Reputation
3 Guides authored
Cal Poly, Team 6-8, Regan Fall 2011 Member of Cal Poly, Team 6-8, Regan Fall 2011
CPSU-REGAN-F11S6G8
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 23
All Time: 8,974
