This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged
  1. Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged, Red side covers: step 1, image 1 of 2 Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged, Red side covers: step 1, image 2 of 2
    • Guide covers disassembly of the side covers of the KRUPS Nespresso XN100 coffee machine.
    • In this machine, removing the covers is mandatory, in order to be able to disassemble the movable front, 'coffee outlet nozzle', the covers hide a small gap, around the contour of the cover, on both sides, via which the front is disassembled by prying.
  2. Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 2, image 1 of 3 Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 2, image 2 of 3 Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 2, image 3 of 3
    • First "Secret" of this machine, the capsule press lever has to be in a certain position—completely closed, otherwise the side covers can't be removed.
    • The covers only come off in this position, since the cover has a cutout on the right side and the handle supports must align with that cutout.
    • To remove the two side screws we use a T10 Torx screwdriver, included in the IFIXIT screwdriver bit kit...
  3. Tool used on this step:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    Buy
  4. Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 4, image 1 of 2 Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 4, image 2 of 2
    • The covers of this machine do not use screws, so you have to pry them with a spatula or prying tool, carefully all along the contour of the machine.
    • With the lid unlatched along its entire length, on both sides, and the handle placed in the cover removal position (capsule press closed), we are left with two latches in the shape of a square ring that joins one lid to the other at the top. We must open the V-shaped lid as if it were a book, since they can break.
    • I wasn't able to take a specific photo of this detail, so I mark the area of ​​the upper latches in one of the previous photos.
  5. Removal of side covers, Nespresso coffee machine, Krups XN100 model Coffee outlet clogged: step 5, image 1 of 1
    • Once the covers have been removed, we must replace the handle, I had not replaced it in the photos yet, but it is better to install it and replace the two Torx screws that hold it, since we need it to move the part of the capsule press.
    • So far the part of removing the covers, in another Guide. I continue with the disassembly of the coffee outlet parrot spout, where the clogs are generated.
    • Insert translation here
To reassemble your device once cleaned, follow these instructions in reverse order.
3 other people completed this guide.
Special thanks to these translators:
es en
75%
Juan Garcia is helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
97,008 Reputation
342 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 155
All Time: 2,763
