Remington WPG4035 Trimmer - check charger contact / repair
  1. Remington WPG4035 Trimmer - check charger contact / repair, Remove head: step 1, image 1 of 1
    • Twist off the head
    Ask FixBot
  2. Remington WPG4035 Trimmer - check charger contact / repair, remove cap: step 2, image 1 of 3 Remington WPG4035 Trimmer - check charger contact / repair, remove cap: step 2, image 2 of 3 Remington WPG4035 Trimmer - check charger contact / repair, remove cap: step 2, image 3 of 3
    • use a stub knife (like the stub side of a butter knife)
    Ask FixBot
  3. Remington WPG4035 Trimmer - check charger contact / repair, open knob: step 3, image 1 of 3 Remington WPG4035 Trimmer - check charger contact / repair, open knob: step 3, image 2 of 3 Remington WPG4035 Trimmer - check charger contact / repair, open knob: step 3, image 3 of 3
    • Carefully lever off the knob with a small knife.
    • To reassemble: This small hook should be in that hole.
    • Take care, to no lose this little part.
    Ask FixBot
  4. Remington WPG4035 Trimmer - check charger contact / repair, remove inner cap: step 4, image 1 of 3 Remington WPG4035 Trimmer - check charger contact / repair, remove inner cap: step 4, image 2 of 3 Remington WPG4035 Trimmer - check charger contact / repair, remove inner cap: step 4, image 3 of 3
    • use a stub knife (like the stub side of a butter knife). Be careful.
    • Your hear a "blob" sound, when a locking is open.
    • There are two hocks on each side, which has hold the outer cap. These may help you to lever up. But stay careful.
    • An image of the two inner locks.
    Ask FixBot
  5. Remington WPG4035 Trimmer - check charger contact / repair, Take out the body: step 5, image 1 of 2 Remington WPG4035 Trimmer - check charger contact / repair, Take out the body: step 5, image 2 of 2
    • use a pliers to pull it out
    • Do not lose this little plastic part.
    Ask FixBot
  6. Remington WPG4035 Trimmer - check charger contact / repair, The Body (just pictures): step 6, image 1 of 2 Remington WPG4035 Trimmer - check charger contact / repair, The Body (just pictures): step 6, image 2 of 2
    • just image, and some technical data (incl. power supply polarity).
    Ask FixBot
  7. Remington WPG4035 Trimmer - check charger contact / repair, Check contact: step 7, image 1 of 2 Remington WPG4035 Trimmer - check charger contact / repair, Check contact: step 7, image 2 of 2
    • We will check for a working connection:
    • Connect the charger.
    • Press all parts together.
    • Connected it only correctly. Not the wrong way round. ( Last image shows the origin. )
    • The LED should now glow (=on):
    • If not: Press a bit more to have a bedder electric contact.
    • Still no LED on?: You Problem are maybe somewhere else.
    Ask FixBot
  8. Remington WPG4035 Trimmer - check charger contact / repair, bend contact out: step 8, image 1 of 2 Remington WPG4035 Trimmer - check charger contact / repair, bend contact out: step 8, image 2 of 2
    • Use a small screw (2mm width, flat) to bend the metal up:
    • 1.) Bend it from inside out.
    • 2.) Bend the two lateral (the tooth) out, to make it more flat (= more narrow / tight).
    • left side: is defect: You should bend it up.
    • right side: OK. So it should look like.
    Ask FixBot
  9. Remington WPG4035 Trimmer - check charger contact / repair, (optional:) rework contact: step 9, image 1 of 1
    • (optional:) Use a soldering station to rework the contact. Especially the contact of charger and battery.
    Ask FixBot
Joe Musters
2,185 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 26
All Time: 120
