Introduction
Sigue esta Guía para remover o reemplazar los tornillos Pentalobe de un iPhone 6s
Remueve los dos tornillos Pentalobe P2 de 3.4 mm que se encuentran cerca del conector Lightning en el borde inferior de tu iPhone.
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
39 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
2 Comments
I noticed both my pentalobe screws wouldn’t screw in last time. Upon checking the little components that the screws fix into were loose inside. Not a major drama but they also seem to hold the charger cable in place… or at least I’ve noticed cables are loose on my iPhone 6 since then. Is there a part I can buy to fix this issue, does anyone know please?
I have an iPhone 6s plus, but I got a new phone recently so I put my 6s plus in my side table and went back to it a couple of weeks later just to see that the pentalobe screws are missing and the phone will no longer charge, I also realized that when I plug the charger in its a bit loose. There was also nothing wrong with the phone before it worked perfectly fine.
