Coloque la Dell Optiplex GX260 sobre una superficie limpia y plana con la parte posterior hacia usted.
Empuje los botones de forma ovalada ubicados en la parte superior e inferior de la PC simultáneamente y levante la caja hacia arriba.
Empuje las lengüetas de color crema en cada lado de cada módulo de RAM hasta que salga y salga de su ranura y retire la RAM.
Desconecte el cable de alimentación ATX de la placa base.
Desconecte el cable de alimentación P4 12V (4x2) de la placa base.
Para volver a armar su dispositivo, siga estas instrucciones en orden inverso.
15 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
4 Comments
Mines stuck for some reason I almost bent the frame from pushing the ports in while lifting and pulling the tray tab away
make sure you doing it the correct side!
muy bueno gracias bro
Mine did not have the big green fan in back. Rest of the disassembly was similar, until I got to actually removing the PCB from the metal back plate. This says to simply slide it forward while holding the plate in place. Yeah… well, in theory. It actually took a fair amount of gentle prying to get the PCB to slide forward. The key is the little metal grounding clips in the corners. The fingers do not actually present much pressure. However, the vertical metal to which they press is an overhang. So the trick is to gently FORCE the PCB forward at each rear corner until such time as the overhang no longer exists. At this point the vertical metal tab will be full back against their respective slots. The PCB will simply lift out then.
