Introduction
Acceder la memoria RAM en este computadora es sencillo y requiere desmontaje mínimo.
Con el estuche cerrado, coloca el Unibody boca arriba sobre una superficie plana.
Presiona el lado ranurado del pestillo de liberación de la puerta de acceso lo suficiente para agarrar el extremo libre. Levanta el pestillo de liberación hasta que quede vertical.
Agarra la lengüeta de plástico translúcido y extrae la batería de la Unibody.
Si se presiona el pestillo, se bloqueará la batería en su lugar.
Retira los siguientes ocho tornillos que sujetan la carcasa inferior al chasis:
Un tornillo Phillips de 5.4 mm.
Tres tornillos Phillips de 14 mm.
Cuatro tornillos Phillips de 3.5 mm.
Libera las pestañas de cada lado del chip empujando simultáneamente cada una de ellas fuera de la RAM.
Para volver a ensamblar tu dispositivo, sigue estas instrucciones en orden inverso.
187 other people completed this guide.
Special thanks to these translators:
100%
Mariana Roca is helping us fix the world! Want to contribute?
Start translating ›
10 Guide Comments
Thank you ifixit. It was a breeze... 8Gb in the house... Best Regards
Hi Bruno!
Assuming you still have the MBP, I am curious to see what memory you installed to get 8 gigs. I just installed 2 X 4 gigs of Kingston PC3 106000 SODIM and my MBP does not want it. My tech assured me that if anything would do it, it was this memory.
Suggestions?
Thank you!
Ghislain
As a breeze. Man, was my computer dirty! Now my computer feels like it's on amphetamines! Lol. So happy the pinwheels are gone. I can finally get work done and feel right about charging my clients hourly!
Installed 8GB of RAM without problems. :)
Been wondering if this system would support 16GB though, given that appropriate modules seem to be on the market, that it has a 64 bit EFI and that the never versions of OS X, booted in the 64 bit kernel (which has been the default mode for a few years, now) obviously support that and more…
