Shop the Holiday Gift Guide
Redragon Impact M908 Scroll Wheel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
113
All Time:
423
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 6 - 9 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The scroll wheel of a mouse is an important part for many quality of life and supplementary features in many programs and video games. While the mouse may still be usable, a malfunctioning scroll wheel can make scrolling websites, zooming, and using many other features difficult. This replacement guide walks you through replacing the Redragon Impact M908's scroll wheel.
Additionally, we use a metal spudger; however, any flat object with a pointed edge will work. Before beginning, ensure your mouse is unplugged from all devices.
Tools
    1. Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: step 1, image 1 of 3 Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: step 1, image 2 of 3 Redragon Impact M908 Scroll Wheel Replacement, TEFLON Feet Pads: step 1, image 3 of 3
      • Make sure your mouse is unplugged from all devices.
      • Pick up your mouse and flip it over.
      • Reposition the mouse so that the four feet pads are facing you.
      Ask FixBot
    2. Redragon Impact M908 Scroll Wheel Replacement: step 2, image 1 of 3 Redragon Impact M908 Scroll Wheel Replacement: step 2, image 2 of 3 Redragon Impact M908 Scroll Wheel Replacement: step 2, image 3 of 3
      • Place the pointed edge of a spudger under the corner of one of the feet pads.
      • Press the tool forward, lifting the foot pad until it is fully removed.
      Ask FixBot
    3. Redragon Impact M908 Scroll Wheel Replacement: step 3, image 1 of 1
      • Repeat the process in step two for the other three feet pads.
      Ask FixBot
    1. Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: step 4, image 1 of 3 Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: step 4, image 2 of 3 Redragon Impact M908 Scroll Wheel Replacement, Scroll Wheel: step 4, image 3 of 3
      • Unscrew the right-hand 3mm screw using a Phillips #000 screwdriver.
      • Unscrew the remaining four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Redragon Impact M908 Scroll Wheel Replacement: step 5, image 1 of 2 Redragon Impact M908 Scroll Wheel Replacement: step 5, image 2 of 2
      • Lift the mouse's top and remove it from the bottom.
      • Place the top to the side, out of the way.
      • The top does not need to be fully removed from the base, and it can be set aside with the connecting cables attached.
      Ask FixBot
    3. Redragon Impact M908 Scroll Wheel Replacement: step 6, image 1 of 3 Redragon Impact M908 Scroll Wheel Replacement: step 6, image 2 of 3 Redragon Impact M908 Scroll Wheel Replacement: step 6, image 3 of 3
      • Identify the scroll wheel in the center of the mouse.
      • Unscrew the 3.5mm screw holding the scroll wheel in place using a Phillips #00 screwdriver.
      Ask FixBot
    4. Redragon Impact M908 Scroll Wheel Replacement: step 7, image 1 of 2 Redragon Impact M908 Scroll Wheel Replacement: step 7, image 2 of 2
      • Lift the scroll wheel and pull it out of the mouse.
      Ask FixBot
Author
with
Alex Johnson
579 Reputation
5 Guides authored
Texas Tech, Team 16-2, Samson Spring 2026 Member of Texas Tech, Team 16-2, Samson Spring 2026
TTU-SAMSON-S26S16G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 113
All Time: 423
