Shop the Holiday Gift Guide
Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
100
All Time:
464
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 35 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The optical sensor is responsible for detecting surface movement as the mouse moves. A malfunctioning optical sensor can make the mouse input feel laggy or erratic, severely reducing its functionality. This replacement guide will walk you through the steps to replace the Redragon Impact M908's Optical Pixart PMW3327 sensor.
Before replacing your Optical Pixart PMW3327 sensor, check our mouse lagging and freezing troubleshooting page to see if the sensor may not be the issue.
Additionally, we use a metal spudger; however, any flat object with a pointed edge will work. A soldering iron is also needed. Before beginning, ensure your mouse is unplugged from all devices.
Tools
    1. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, TEFLON Feet Pads: step 1, image 1 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, TEFLON Feet Pads: step 1, image 2 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, TEFLON Feet Pads: step 1, image 3 of 3
      • Make sure your mouse is unplugged from all devices.
      • Pick up your mouse and flip it over.
      • Reposition the mouse so that the four feet pads are facing you.
      Ask FixBot
    2. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 2, image 1 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 2, image 2 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 2, image 3 of 3
      • Place the pointed edge of a spudger under the corner of one of the feet pads.
      • Press the tool forward, lifting the foot pad until it is fully removed.
      Ask FixBot
    3. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 3, image 1 of 1
      • Repeat the process in step two for the other three feet pads.
      Ask FixBot
    1. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, Optical Pixart PMW3327 Sensor: step 4, image 1 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, Optical Pixart PMW3327 Sensor: step 4, image 2 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement, Optical Pixart PMW3327 Sensor: step 4, image 3 of 3
      • Unscrew the right 3mm screw using a Phillips #000 screwdriver.
      • Unscrew the remaining four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 5, image 1 of 2 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 5, image 2 of 2
      • Lift the mouse's top and remove it from the bottom.
      • Place the top to the side, out of the way.
      • The top does not need to be fully removed from the base, and it can be set aside with the connecting cables attached.
      Ask FixBot
    3. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 6, image 1 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 6, image 2 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 6, image 3 of 3
      • Unscrew the 3.5mm screw holding the circuit board in place near the scroll wheel using a Phillips #00 screwdriver.
      Ask FixBot
    4. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 7, image 1 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 7, image 2 of 3 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 7, image 3 of 3
      • Flip over the circuit board.
      • Identify the optical sensor.
      Ask FixBot
    5. Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 8, image 1 of 2 Redragon Impact M908 Optical Pixart PMW3327 Sensor Replacement: step 8, image 2 of 2
      • Use the soldering iron to desolder the first optical sensor pin.
      • Repeat for the remaining 7 pins.
      Ask FixBot
Author
with
Alex Johnson
579 Reputation
5 Guides authored
Texas Tech, Team 16-2, Samson Spring 2026 Member of Texas Tech, Team 16-2, Samson Spring 2026
TTU-SAMSON-S26S16G2
5 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 100
All Time: 464
